Cannot find a Gasket for the differential
Old Mar 7, 2013 | 11:59 AM
Premier1one's Avatar
Default Cannot find a Gasket for the differential
I'm trying to locate (on the web) a Gasket for the differential cover for a 1997 XK8. Supposedly they are sealed for life, but I want to get in there while the Rear end is out just to check it out. The fluid really should be changed IMO and there's a chance there is a lot of sludge not to mention possible metal shavings. Worst case scenario I'll just make my own. Oh what kind of fluid should I use? Have not researched that, but just throwing it out there
Thanks anyone/ everyone
Bruce
Old Mar 7, 2013 | 12:35 PM
Jacsun's Avatar
Maybe try the word "seal". I typed "97 XK8 Differential Seal" and got lots of options on a Google search. Jagbits being one of them.
Also, here is a link on the fluid. See GGG link in #2 of this.
https://www.jaguarforums.com/forum/x...iff-xkr-91112/
Lastly, that fill plug is a bear to get to when the Diff is on the car from what I understand. I read on the forum that one of the guys drilled and tapped for a more accessible plug. Something to think about when you have the opportunity you do right now!
Old Mar 7, 2013 | 01:20 PM
Originally Posted by Premier1one
I'm trying to locate (on the web) a Gasket for the differential cover for a 1997 XK8. ...............
Bruce,
The Parts Catalogue doesn't list a gasket for the cover.
Usually this happens where RTF is used as a sealant.
Attached Thumbnails Cannot find a Gasket for the differential-xk8-differential.jpg
Old Mar 7, 2013 | 05:59 PM
Graham- it does look as if this is the case/ Dried oozing from the original install
Thank you
Old Mar 7, 2013 | 11:02 PM
avos's Avatar
You can use liquid gasket for the cover.
Old Mar 8, 2013 | 01:06 AM
XKRacer's Avatar
I use a liquid sealer made by Wurth, works very well as I refuse to use RTV
FrickenJag
Jun 16, 2025 02:15 PM
aholbro1
Dec 29, 2024 06:46 PM
vicom
Sep 17, 2015 03:32 AM
hoodun
Sep 7, 2015 07:02 PM
Wes Steenrod
Sep 6, 2015 06:52 PM
