Can't unplug seat module
2006 XK8 got seat modules loose and wanted to test working driver seat module on non-working passenger seat controls. Can't seem to get module unplugged by pulling out. Is there a clip or other that is holding the plugs in or just stuck? Any suggestions how to loosen them?
Thanks!
Thanks!
If you have removed the fasteners from the module and the module from the bracket, you should have enough slack to pull the module out from under the seat where you will have plenty of visibility. The tang to press will be apparent.
It does take some wiggling, even with the tang pressed. It won't feel like anything's happening, and then it will just come free. It takes as much faith as it does patience and finger strength. ;-)
Gus
Sep 1, 2016 09:47 PM
xjrjag
Apr 14, 2016 11:57 AM
