Car Cover - squirrel or bird problem
I am very well pleased to use a car cover for my 2005 XK8 Convertible. My assigned parking place is under trees which means bird droppings, sap, leaves, twigs, and then there's pollen in the spring. I have had a Block-it Evolution car cover for about four years. It was still functional, but there was reason to replace it. I now have a Block-it Noah car cover and hesitate using it before I resolve the following problem.
For the Evolution car cover I could observe birds and squirrels pecking away at the material and actually penetrating it. I really can't say which animal was causing the damage.
Does anyone have any experience with this? Is there an anti-"varmint" spray or chemical that you might suggest?
WGS (03-08-2013)
I have used moth ***** and ammonia in my boat under the cover to keep cats out. I put some moth ***** under my car and under then hood when I had a mouse problem and that worked.
If you can figure out a way to use either of these it might work. In my usages they were not open to sunlight and so forth. I put a shallow pan of ammonia in my boat and just threw some moth ***** around. I don't know how you could use either of these on top of a car out in the open.
I have a coraplast sign that I put over my top at home to keep the cats off. Good luck, I am sure that it is very annoying.
WGS (03-08-2013)
Thanks for your replies. I had planned to experiment with moth *****. Many years ago I had used them in Vermont to keep porcupines from chewing up tires, brake lines, anything plastic or salty. Nothing worked until I wrapped the car in chicken wire.
My new car cover is still in the carton. I will pour in a bunch of moth ***** and let it sit for a while before I use the new cover.
I hope moth ***** are still paradichlorobenzene. There's probably a law against them now.
Fox and Coyote urine is a great rodent repellent. Now of course it's up to you on how to gather all the secret ingredients to that formula. I've used a product called "Shake Away" with pretty good results for mice,rats and chipmunks in my outdoor grill. I put some of the granular product in a cup in the storage area under the grill---have not seen mice droppings at all this winter. The scent might not be real attractive on your car cover.
BrentGardner
28
04-26-2024 03:08 AM
xjrjag
10-27-2021 11:48 PM
FS[SouthEast]: 2005 Jaguar XKR Convertible Supercharged
divingmom
08-25-2015 07:54 PM
