car leans a bit in turns
Old Jun 7, 2025 | 09:42 AM
wreckless1's Avatar
Default car leans a bit in turns
My 2006 XKR with 84000 miles leans a bit in turns. I know my front control arm bushings are a bit worn. Would replacing them do much to improve that issue. Where else should I look if that would not make much difference?
Old Jun 7, 2025 | 11:07 AM
STLTHMSTA's Avatar
Springs could be getting soft, new shocks may slow it down but the springs are holding the car up, or not. TM
Old Jun 7, 2025 | 06:54 PM
RJ237's Avatar
It's a touring car, not a GT3.
Old Jun 7, 2025 | 07:02 PM
wreckless1's Avatar
Don"t get me wrong, I like the car and I have had it for 15 years. I had not driven it in a while and I just noticed that my Lincoln Continental has less roll than this car which surprises me, thought it might need something.
Old Jun 7, 2025 | 07:28 PM
baxtor's Avatar
How is your stabilizer bar fixings, l have always appreciated how flat my own XKR turns, can't imagine a continental doing better.
Old Jun 7, 2025 | 07:47 PM
wreckless1's Avatar
Yeah I thought the same thing, but the Continental is a really great handling car. I generally set it normal suspension but it 's handling in sport mode is really tight, the comfort mode is squishy though. Too bad they don't make them anymore. Must be something that is off on my Jag. I have not looked at the rear suspension, but only noticed the bushings up front.
Old Jun 7, 2025 | 07:57 PM
giandanielxk8's Avatar
Your suspension is probablyneeding a refresh, as pointed out. That's probably the biggest factor. I would argue that there's another issue that may be contributing to how much it feels like the car is leaning in the corners, particularly under spirited driving. The seats offer almost no lateral support. It's too easy to slip and slide out of the seats. By not being securely held in place, I imagine it amplifies the sensation of body roll. It might not be the car's body that's rolling, but instead your own body.
Old Jun 7, 2025 | 08:07 PM
wreckless1's Avatar
[QUOTE=giandanielxk8;2849410]Your suspension is probablyneeding a refresh, as pointed out. That's probably the biggest factor. I would argue that there's another issue that may be contributing to how much it feels like the car is leaning in the corners, particularly under spirited driving. The seats offer almost no lateral support. It's too easy to slip and slide out of the seats. By not being securely held in place, I imagine it amplifies the sensation of body roll. It might not be the car's body that's rolling, but instead your own body.[/QUOTE
That made me laugh, at 6’1” and 220 lbs. i don’t do much sliding in the seat.
Old Jun 8, 2025 | 07:08 AM
[QUOTE=wreckless1;2849417]
Haha, then you’re not cornering hard enough. I would check the anti-roll bar bushes and links, the shock absorbers, and the springs.
jim_63219
Oct 22, 2024 05:14 PM
Reaxions
Sep 30, 2023 07:24 PM
Busa196
Feb 15, 2023 09:46 AM
sknight751
Jun 28, 2020 11:43 AM
