Car wont start... Help!
Old 07-10-2012, 10:00 PM
obeymukie's Avatar
Unhappy Car wont start... Help!
I tried to start my car this morning only to come to find out it wont start. After trying to start it a message popped up and said "ASC and TRAC not available". So I pulled out my scanner to find only two error codes P0455 and P1000. Please help i cant get the car started at all.
Thanks for your time and help.
By the way the car is 2000 Jaguar convertible XK8
Old 07-10-2012, 10:14 PM
mrlovt's Avatar
P1000 basically means that the testing cycle is incomplete. This is because you have (or have recently had) a trouble code, in this case P0455. It will go away after the problem is resolved and a number of drive cycles have completed. P0455 is usually caused by a loose gas cap, but that won't prevent your car from starting. It might help if you could give us other symptoms. Does it turn over? Start with the basics: check for a good battery and connection, fuel at the rail, and spark. Also, read this: https://www.jaguarforums.com/forum/g...d-first-30792/ That comes from the XK8 FAQ: https://www.jaguarforums.com/forum/x...ts-data-29800/
Let us know what's going on!
Old 07-10-2012, 11:07 PM
Paul Pavlik's Avatar
Possibly the Fuel Pump. One test is to connect a Fuel Pressure Gauge to the Schrader Valve on the rear of the right side Fuel Rail.
Old 07-19-2012, 01:14 AM
obeymukie's Avatar
Sorry for taking so long to respond but i've just been really busy with work and school. So after that last post I did. I decided to clear the codes and try to start it. I know it wont solve the problem but I just wanted to see if the car would start and sure enough it did. Car started up fine without any problems. After a week later Im driving back home from the store and all of sudden the car feels like its ready to shut off so i pull over and I see this thing saying "restricted performance". So i ended up having to tow the car home. So I take out my handy obd scanner and P0353 and P1000 pop up. I know its a Ignition Coil problem, what would be the best way of fixing this problem? Again thanks for the help!
Old 07-19-2012, 03:03 AM
GGG is offline
Received 16,823 Likes on 12,178 Posts
P0353 = Ignition Coil (A3) primary / secondary circuit malfunction
To test whether it's a faulty coil or a circuit fault, switch the coil with any other. Clear the codes and see if the error changes to the new location. If it does, it's the coil.
Old 07-19-2012, 08:21 AM
This Diagram may help to clarify Cylinder Identification:
rvdz
12-07-2019 06:42 AM
msdg137
09-16-2015 06:24 AM
Jandreu
08-29-2015 07:31 PM
SingBlueSilver
08-27-2015 02:20 PM
Vector
US Lower Atlantic
08-26-2015 05:36 AM
Quick Reply: Car wont start... Help!
