The Cat will not start!
Old Nov 4, 2009 | 11:47 AM
XKRCoupeMan's Avatar
Anybody have any experience using an aftermarket fuel pump made by Airtex, part# E2226. I see this on e-bay selling for $40. If I can save $400 my wife will be very happy!
Old Nov 4, 2009 | 01:40 PM
eaglexkr's Avatar
I got mine from the Parts Geeks:
http://www.partsgeek.com/catalog/200...fuel_pump.html
It was about 131.00 for the pump and another 20.00 for the screen filter.Based on the work and effort to get the tank out and replace the pumps,I would invest in a better pump than one on ebay.There is also Ken at Motorcars Ltd,which supports this forum.
Old Nov 4, 2009 | 03:44 PM
eaglexkr's Avatar
Smile
One more thing on the fuel pump. The Proper number for your car is
AIRTEX Part # E2471 if you want to install a service grade ,the going price for that pump is around $80.00 or you can go to a OEM grade for $130.00-$150 per pump,screens are about the same for either types.So if it were me and I was going to keep the car for a couple of years and did 4 to 6 hours of labor,I would go with the OEM grade.The dealer will charge you a min of $1300.00 to do the job.So tell you wife you saved almost a $1000.00(the fuel line release tool will be less then $10.00)and buy the better pumps.Your
call.
Old Nov 4, 2009 | 04:32 PM
oldmots's Avatar
I suggest that you check the fuses and relays for the fuel pumps. It would be unusual for both to fail at once and the car should start on one. There are two and if it's set up like the XJR, the second pump starts at 4000 engine rpm. If these things are good, check the pump harnesses as there have been problems with these. Fuel pumps should last 100,000 miles unless the car tank is always below 1/4 and the pumps are always in the open without the fuel to keep them cool.
Old Nov 6, 2009 | 04:54 PM
eaglexkr's Avatar
Just to comment on the advice of check the fuse,if the fuse did blow it is most likely because the harness to the pumps has shorted.Guess what,you have to remove the tank to get at it,and if I am that far into the tank,I would replace the pumps.Pumps are motors and are working whenever the engine is running.A relay is less likely to fail, it has a coil that holds the contacts when energized and goes from one cycle (on-off)everytime you run the engine.As far as the subject of running the gas level below a 1/4 of a tank is a bit of a myth.The gas going through the pump really is what will cool the pump.
Old Nov 9, 2009 | 08:55 PM
brgjag's Avatar
Originally Posted by brgjag
thanks for the answer TEST. good to know I have jsut one pump! Assuming my pump is orig on my 97 with 75k, what is the expected lifespan of these pumps. Are the old myths of running with atleast a half tank of gas to keep the pumps cool for real???
Anyone?
Old Dec 12, 2009 | 11:38 AM
Update on my origianl post: The CAT IS ALIVE AGAIN!
I replaced both fuel pumps and filter screens (Parts Geek $305) and it fired right up! It is now running great, and it seems to have better response (maybe I was ruinning on one pump for awhile!) Not an easy job but not too bad once you get the lines disconnected underneath! Thanks to everyone for the advice and info.
Old Dec 12, 2009 | 12:32 PM
  #28
Gus's Avatar
Gus
Good to hear!
Old Dec 12, 2009 | 03:55 PM
eaglexkr's Avatar
Smile
I felt your pain,been there done that.Glad to see you went with the pumps from Partgeeks, its too much labor to risk low end parts.Wasn't it fun getting the fuel lines off!!Good to see you are back on the road.
philwarner
Oct 4, 2024 01:37 PM
Aus V8S
Nov 13, 2015 11:01 AM
Bones
Sep 8, 2015 08:34 PM
02jagstype
Sep 4, 2015 08:20 PM
rachelstr
Sep 3, 2015 12:59 PM
