CEL P0171 code
Old Apr 23, 2014 | 04:29 PM
Redeye's Avatar
Default CEL P0171 code
Ive read a lot on the fourm about this code and roughly know what the short list of culprits might be, so got a good idea what, but don't know for sure. A potted history of recent events:
  1. Everything running perfectly for past couple of years
  2. Recent full service (incl fuel filter, trans oil/filter, front pads)
  3. Within 50 miles CEL comes on
  4. Hook up to OBD2/app and the P0171 code is now showing
  5. Restricted Perf comes on and off every now and then
  6. Cleaned MAF sensor with res free electrical cleaner (was really clean anyhow)
  7. Took off air intake between MAF and TB, cleaned and checked for cracks (NOTHING)
  8. Cleaned TB with CRC cleaner - was a bit mucky I suppose
  9. Checked for leaks all over the shop with soapy water sprayer w engine on (no change in revs AT ALL)
  10. Did hard reset and cleared the fault codes.
  11. 50 miles or so later CEL back on with P0171!!!!!!!!!
Ran a diagnostic with Torque Pro (only went a few miles, and have not done that many since hard reset). Results:
  1. Fuel pres 54.8psi
  2. Intake 4.5psi
  3. MAF 4.8g/s
  4. STFT1 -2.3%
  5. STFT2 0%
  6. LTFT1 18%
  7. LTFT2 16.4%
  8. Volts 13.2
  9. O2S1Eq 1.0
  10. Av CO2 485g/km
  11. Vacuum 208in/Hg
  12. O2 1x2 0.8v
  13. O2 2x2 0.6v
  14. Boost -10.2psi
Now, I have NO idea what any of the above means, so am hoping the wise ones of you good folk out there can help me pin point what the issue is.
Worth mentioning I've been getting some slight surging now at low revs with little throttle (nothing at speed), plus some weird sweet smells from engine immediately after start up.
All help greatly appreciated.
Jules
Old Apr 24, 2014 | 01:53 AM
JagV8's Avatar
Just do the LTFTs at idle & about 2500rpm, engine hot, parked. If they head towards zero you've an air leak (which is what the code is suggesting).
Old Apr 24, 2014 | 07:45 AM
Redeye's Avatar
Idle:
LTFT1 18
LTFT2 16.4
2500 revs:
LTFT1 4.3
LTFT2 3.1
I guess this confirms an air leak somewhere? Could faulty spark plugs (misfires) also cause this tho as the sensors are seeing extra air?
Old Apr 24, 2014 | 08:07 AM
RaceDiagnostics's Avatar
I think you would notice the misfire if you had one.
Looks like it is time for the homemade smoke machine.
Old Apr 24, 2014 | 10:44 AM
JagV8's Avatar
Originally Posted by Redeye
Idle:
LTFT1 18
LTFT2 16.4
2500 revs:
LTFT1 4.3
LTFT2 3.1
Classic air leak. I think you'd need every plug/coil to equally misfire and yet be undetected as misfir codes to replicate it - i.e. ain't gonna happen.
Looks like the leak is similar bank-to-bank so may well be something shared.
Smoke - looks a good idea!
Old Apr 24, 2014 | 10:51 AM
Redeye's Avatar
I've had several over the past few days...!
Old Apr 27, 2014 | 12:43 PM
Redeye's Avatar
Ok, not sure whether to laugh or cry!
Convinced this was an air leak and not being savvy enough to rig up the smoke test, I booked the cat in to the garage - was due in this Wednesday - and had already started busking on the streets in readiness for some horrendeous bill. As I do lots, had been searching the forum and I stumbled across a thread from our XJR friends who had similar issues, which gave a list of 'obvious' things to check. One of which was the o ring on the dip stick and another was to check the oil filler cap. So in hope I trundled out to do the checks and the dip stick seal was fine, but..... THE OIL FILLER CAP WAS ONLY HALF DONE UP!!!! Re sealed it and went out for a few miles drive with my Torque app on. Got back and the LTFT had fallen from 19.5 on both banks to 6.5 and 7, and they did not drop when I was in park and got to 2.5k revs!
Could this be the reason??? If so obviously im really happy and I will monitor closely over the next few days. If it is, then said garage wont be seeing me again any time soon!
Thanks again to those folk who offered up help here.
Jules
Old Apr 27, 2014 | 01:05 PM
JagV8's Avatar
Yes, of course it can be and from your readings could well have been.
clubairth1
30
Sep 3, 2025 04:38 PM
KarimPA
Sep 27, 2015 08:46 AM
Jagged-X
Sep 24, 2015 05:08 PM
swetnK
Sep 24, 2015 07:55 AM
Bob Gelston
Sep 14, 2015 11:08 PM
