Center console/ashtray cover.
Old Oct 4, 2018 | 03:59 PM
mcook's Avatar
Default Center console/ashtray cover.
Hi,
Does anyone have or know where I can get a drawing of the center console? The panel covering my ashtray/cigar lighter does not work properly,
and before I go charging in there I would prefer to have an idea what I am looking for.
Old Oct 4, 2018 | 05:32 PM
avern1's Avatar
To remove and work on the ashtray you will need to remove the entire center console and turn it over to access the mounting. I have attached a picture.
Old Oct 5, 2018 | 07:33 AM
mcook's Avatar
Thanks. I am going to get to work on that this morning.
Old Oct 5, 2018 | 01:38 PM
frankc's Avatar
Before you start pulling it to bits can I ask if by "it does not work properly" means it does not open easy? i.e You push down on the front and it does not open as it should? If this is the case simply get a can of WD40, or similar, with a straw. Open up the flap if you can and spray down the back of it where the hinges are. Grab the front with your fingers and work the flap up and down to ensure the lubricant penetrates everywhere. You will then find it opens nicely. Especially after its had some time to work.
Blake Bias
Oct 27, 2016 03:52 PM
jahummer
Feb 10, 2015 04:08 PM
XJsc-guy
Dec 24, 2013 12:49 PM
soonerpride316
Jun 6, 2011 08:38 AM
hevnbound
Oct 27, 2010 01:36 PM
