central locking key fob problem
Old Jan 3, 2010 | 09:08 AM
neemo's Avatar
Default central locking key fob problem
Hi all
im Neemo and new to the Forum
i purchased an 1996 XK8 yesterday, and the car has some minor faults.
firstly is the drivers window dropping in stages and not comming back up
due to this brilliant forum ive found out how to repair it
but my main problem is the remote fob/central locking.
the central locking is very intermittent
the unlock button works and so does the light and remote boot/trunk button
but the car wont lock on the lock button
it has worked maybe 2 out of 10 times
also the car will not lock with the key, if i try to lock it with the key the alarm sounds?
can anyone help please
Old Jan 3, 2010 | 09:56 AM
Gus's Avatar
Gus
I have little or no experience in this area but will give you my input. If it were just the remote cleaning it may help. You can go to my page and to the left you will see Jag xk8 remote click on it and you will see what I found and how to clean it. As for the key locking setting off the alarm I would check that all switches related to the security system were working properly. It seems to me if one were not open or closed to satisfy the security system it will do what it is doing to you.
Old Jan 3, 2010 | 02:06 PM
H20boy's Avatar
door latch assembly replacement are common to these cars, perhaps related...
Old Jan 3, 2010 | 05:35 PM
OregonJag's Avatar
..what Gus said.
Cleaning the remote on the inside makes a big difference. You'll probably find a big blob of oily substance under the lock button. It did make a difference in mine anyway. Don't expect these remotes to have any range. They're like my '96 pickup, you've got to be almost on top of the vehicle for them to work. I suspect later years were much better.
Old Jan 3, 2010 | 05:39 PM
neemo's Avatar
cheers for the tips Gents
ill strip it down tomorrow
thanks.
Old Jan 3, 2010 | 07:33 PM
Gus's Avatar
Gus
For what it is worth and I have no idea why I get better range when I hold the remote vertically and pressing the button.
Old Jan 3, 2010 | 07:43 PM
OregonJag's Avatar
Curious, will your key in the door-lock-cylinder lower the windows and top if you hold it in the position to the right (clockwise)? You should be able to raise and lower the top with the key in the door. Clockwise lowers, counter clockwise raises the top. It takes a while to go through all the steps, be patient.
Also, when you step out of the car and the window has lost its memory..again, use the key to raise it by turning counter clockwise. There is a couple of seconds delay before it acts.
This all assumes it doesn't set of the alarm again.
Good luck. I've learned a good bit about my car in the two months I've had my '97.
Mike
Old Jan 4, 2010 | 06:03 PM
victor_4488's Avatar
@Gus:
Use capacitive coupling to increase the range of your remote keyfob. As documented by the New Scientist article, place your remote under your chin (or any other body part) and push the button to increase its range.
http://web.archive.org/web/200406031...e.jsp?id=lw962
Old Jan 4, 2010 | 06:56 PM
test point's Avatar
How about your hand?
Old Jan 4, 2010 | 07:01 PM
Not sure of the specifics, but after reading the article, I gather that the conductive material in your hand is minimal compared to your head/torso so the amplification of the RF signal would be minimal... try it under your chin.. it really works!
Old Jan 4, 2010 | 07:20 PM
Gus's Avatar
Gus
So what you are saying is that if I stick my remote up my A__ it will work better?????? Only kidding! Only Kidding!!
Old Jan 5, 2010 | 07:22 PM
hlgeorge's Avatar
Let us know how it works Gus!!?? Not kidding!
Old Jan 6, 2010 | 09:25 AM
Gus's Avatar
Gus
Ouch!!
Old Jan 10, 2010 | 07:29 AM
cafepombo's Avatar
I posted a solution to the original problem of intermittent key fob in the XJR forum.
Old Jan 12, 2010 | 03:55 PM
neemo's Avatar
Cafepombo your a star
what i had to do was retrace the curcuit board
and its working a dream
cheers
Old Aug 14, 2012 | 10:23 AM
bobtot's Avatar
Smile Brilliant
May be an old post but its just saved my bacon & sorted my key fob out a treat, take it apart and give it a clean, dirty black gunk under the buttons!! Its never worked better....cheers guys!!
Old Aug 14, 2012 | 12:49 PM
Jon89's Avatar
Yep, some alcohol and Q-tips can work magic with these grungy key fob innards. Had to change the battery in my S-Type key fob just an hour or so ago. While I had it apart for the battery change, I gave it a decent cleaning....
Old Aug 14, 2012 | 06:18 PM
Gus's Avatar
Gus
See if this link helps the next person
Link: JagRepair.com - Jaguar Repair Information Resource
99xk8guy
Sep 29, 2025 10:51 PM
philwarner
Oct 4, 2024 01:37 PM
Wolfy
May 28, 2024 08:06 AM
XJsc-guy
Nov 23, 2015 01:56 PM
jdzubas
Oct 4, 2015 09:14 AM
