Central Locking Problems xk8
Old Jun 8, 2008 | 10:12 AM
jag_genius's Avatar
Default RE: Central Locking Problems xk8
check you battery
Old Jun 8, 2008 | 07:49 PM
hlgeorge's Avatar
On #5, check your owner's manual. It will tell you how to reset the windows. As j_g says, the computers go squirrely with a battery that is not up to par.
Old Jun 9, 2008 | 01:10 PM
hlgeorge's Avatar
I would just try a reboot and see what happens. Disconnect the battery for a minute or so and reconnect it. Let it sit for a few minutes. Of course you will have to reprogram the windows again.
Old Jun 9, 2008 | 05:50 PM
test point's Avatar
Mostauto part stores will do a battery test for free, hoping to sell you a battery. The voltage guage is an 'idiot guage', it always reads in the middle unless the system has completely failed.
Old Jun 9, 2008 | 07:33 PM
lockgirl's Avatar
I had the same problem. Appx $125 installed by the great guys at my localAdvanced Auto Parts. They even took the time to hook up a secondary battery so myvehicle programming stayed (radio,#1, #2 settings,etc)as they made the change.
Poof - problems gone!
Old Jun 9, 2008 | 09:17 PM
jag_genius's Avatar
does it lock then.. after tick..tick.. then unlock..?
Old Jun 12, 2008 | 04:36 PM
test point's Avatar
Please forgive if I am being doubly redundent but everything you describe still could be a marginal battery. Try simple first.
Old Apr 28, 2014 | 01:38 PM
Carmow's Avatar
Has anyone ever got to the bottom of what to do to cure this problem?
Old Sep 23, 2014 | 03:22 PM
Nonoproton's Avatar
Default Possible answer?
I've been having this exact same problem on my 2000 xkr! Went to the dealer, they said it was a door microswitch problem, which was going to cost about €400,- per door! Although you can biy the parts yourself and possibly fix the problem. Here's a link to a video of how it should be done:
http://youtu.be/DV1hy3AYni0
Alhough i haven't tried this yet due to a lack of time.
Furthermore i found a possible second option, it is said you can clean this microswitch yourself, here's a link to that post:
https://www.jaguarforums.com/forum/xk8-xkr-17/success-passenger-door-microswitch-90184/?styleid=5
Have been suffering from this problem quite a while now, especially when the alarm goes of at 3am is startink to wear me out
Anyway, hope this helps, please let me know if it does!
Greetings
Old Sep 23, 2014 | 06:03 PM
Jandreu's Avatar
Sounds like the door micro switch to me, see post >#6 here for info and links:
https://www.jaguarforums.com/forum/x...roject-118210/
Old Jun 21, 2019 | 12:49 PM
Marqymarquis's Avatar
Default Exactly the same on my XK8
Originally Posted by NickHanson
Hi
Can anybody help me - Yesterday my 1997 XK8 coupe central locking stopped working - in addition a few other things occurred :
1. Remote switches off alarm/opens boot and operate headlights but does not open the car
2. Key works ok but just the driver door unlocks - not the passenger door
3. Doors do not lock on drive away anymore.
4. Windows godown the small amount to open the door but does not go back up when you close the door.
5. everytime you pull the door handle the window goes down a small amount - e.g if you pull the door handle 5 times the window goes down 5 times
Nick
The same thing happens on my XK8 every couple of weeks. The problem usually only affects the driver’s door (R/H side as I am in England).
i have replaced the module inside the driver’s door but this has had no effect. The only cure I have found is to disconnect the battery for a few minutes. The car then needs to be left to “sort itself out” for a while (ten minutes or so); then the window max lift and drop positions can be reset and the system will work as it should for another two weeks or so.
I am now contemplating changing the central locking module which is located in the boot (trunk) underneath the fuse box on the right hand side rear wards of the battery.
Mark, Worthing, Sussex, England
Old Jun 21, 2019 | 12:58 PM
DavidYau's Avatar
Default That’s a seriously old thread... but still resonates... probably for all eternity
Check
1. Battery
2. Battery cables’ connections
3. Door cable connections
4. Microswitches
4. Door control module
5. Security module
bet it’s no.1 or 2
Old Jan 15, 2020 | 07:45 AM
JayJagJay's Avatar
Originally Posted by DavidYau
Check
1. Battery
4. Microswitches
5. Security module
bet it’s no.1 or 2
HI DAVID! Brother, You're everywhere, lol....
Guess why I'm reading this!?
Old May 6, 2024 | 07:18 AM
Scoobiefan's Avatar
Hello Mark,
Did you ever resolve your issue? My 2001 XK8 is behaving very oddly with the door locking. Did you replace the control module?
Thanks,
Tim
Worthing, Sussex
toronadomike
Jan 22, 2026 10:13 PM
99xk8guy
Sep 29, 2025 10:51 PM
XJsc-guy
Nov 23, 2015 01:56 PM
obwoodie
Sep 3, 2015 07:45 PM
laserguy
Sep 3, 2015 02:02 PM
