Cheap arse plastics in the xk8
Old Sep 17, 2012 | 08:25 AM
  #41
dennisw's Avatar
Originally Posted by tippytoe
If the people at Jaguar want to look at how a quality car is built, they should just look to Lexus. A LS Lexus is 100% more the luxury car than a jag. There are some that are 22 years old now and still in one piece (no crumping plastic, no mandatory replacing plastic parts for metal) and running well.
It can be done. And when you get upwards of $70,000, I expect a car to be made of the absolute best materials. A Kia, not so much
wouldnt be seen dead in toyota
Old Sep 17, 2012 | 09:31 AM
  #42
RCSign's Avatar
As written by Tippytoe
If the people at Jaguar want to look at how a quality car is built, they should just look to Lexus. A LS Lexus is 100% more the luxurycar than a jag. There are some that are 22 years old now and still in one piece (no crumping plastic, no mandatory replacing plastic parts for metal) and running well.
As a previous owner of two Lexus's SC300 and LS400 they do run well but the plastics crack, wood finishes deteriorating, LED's fading out, plastic radiators cracking, etc.. We did use these cars for everyday use. I don't use my Jag everyday, and it's garaged most of the time, But I haven't had only two plastic pieces break, The radiator hose spacer type clamp otherwise all of my plastic in good shape.
Old Sep 17, 2012 | 09:40 AM
  #43
2002XK8Orlando's Avatar
Funny thing is, when you get a car that has no little nit picky things and everything is perfect and refined, then it somehow looses its "soul."
A new Lexus is a very nice car. Nothing much to change..nearly perfect and very refined...but alas it is a souless wonder.
And for the record I don't see any 22 year old Lexus' around that are in great shape. Most fall into the hooptie category. And many that are as old as my car (an '02) don't look near as good with their opaque oxidized headlights, cracked seats and fading tailights.
Old Sep 17, 2012 | 10:26 AM
  #44
H20boy's Avatar
How true! Don't see any jaguar's of any age with plastic headlamps that turn yellow, do ya?
Old Sep 17, 2012 | 05:26 PM
  #45
No xk8/xkr's. I do see s-types though but no others
Old Nov 12, 2012 | 09:32 AM
  #46
Graham Royls's Avatar
Rather than break a plastic clip , how do you open the clips on plastic hoses to cooling system when tube/hose pops out?
Old Nov 17, 2012 | 04:43 AM
  #47
Regarding broken clips or plastic tubes/hoses for windshield washer and plastic clips. Had 2 broken and instead of replacing i drilled out broken tube from clip. Cut a piece of plastic tubing{ from caulking {foam] cartridge } inserted in clip {super glued} . Expanded washer tube { warm water} and inserted it on plastic tube insert.
In both cases it was not necessary to remove clips that are fragile at very best.
Old Nov 17, 2012 | 11:43 AM
  #48
SeismicGuy's Avatar
Graham--Do you have a pic of the fix that you are describing?
Doug
duecedriver
Dec 25, 2015 11:47 AM
indi4ever
Oct 8, 2015 10:23 AM
Philurusso
Sep 20, 2015 07:02 AM
SeanU
Sep 14, 2015 04:31 PM
jaaag
Sep 11, 2015 12:53 AM
