Chipped Harmonic Balancer
Old Oct 13, 2011 | 01:47 PM
randyb's Avatar
Originally Posted by XKRacer
I think I would put it up on a lathe and machine it out/round again, you dont need the big lip there to hold the belt, would be a 5 minute job a machine shop would only charge a few bux for it, as long as something was left behind, I could live with that.
Yes and rebalance.
Todays engines REALLY do not like vibration.
Call a junk yard or check ebay, but I would not leave it like it is. Like Fram used to say, you can pay a little now or a lot later.
Old Oct 13, 2011 | 02:24 PM
dennisw's Avatar
what does it do and where do i find it on my xkr?
Old Oct 13, 2011 | 02:36 PM
Brutal's Avatar
Originally Posted by abee
will Jaguar XK8 XKR 2001 harmonic balancer be compatible with the jaguar xjr 2000 harmonic balancer?
97v8's to 2003 should all be the same. normally aspirated and supercharged are not though. youll need to send yours as a core, butif its cracked you may have to pay the core charge as its not rebuildable
Old Oct 14, 2011 | 02:27 AM
XKRacer's Avatar
They are talking about the main front pulley, between the pulley and centre where it slides onto the crankshaft there is a rubber section, this can break up in time and is what is called the harmonic balancer, what it does is minimise vibration from the crank
Old Oct 14, 2011 | 05:06 AM
dennisw's Avatar
many thanks for the info
Old Nov 25, 2011 | 08:42 PM
rlindsey's Avatar
I am trying to get the harmonic balancer off my 4.0 L V-8 2002 S-Type. Does the big nut, 24MM turn left to loosen like a normal bolt or is it reverse threaded? It doesn't seem to want to budge!
Thanks,
Richard Lindsey
Old Nov 26, 2011 | 12:34 AM
XKRacer's Avatar
Yep it is a normal threaded bolt but done up very tight 350nm, you will need to hold the crank still whilst you are trying to undo it
Old Nov 26, 2011 | 06:00 AM
  #28
ooootis's Avatar
Originally Posted by smokphattys
wrong puller, stupid mistake, so you think it will be ok then, dont bother buying a new one? heres a pic
I'm going to assume that the balancer that you posted a picture of is indeed the one you are referring to. Replace it now!! The elastomeric rubber is cracked and dry rotted. I don't know how much pressure was exerted to the outter ring of the balance, that didn't help the rubber a bit. Then there is the matter of the chipped casting.
The weight of the balancer is important for complete dynamic balancing of the internal rotating components as well as canceling destructive harmonic resonances. These frequencies are read in IPS (inches per second) and are measurable with accelerometers placed on certain portions of the engine at certain RPM. The upper band of resonance can destroy crackshafts, bearings, cams etc.
I saw a suggestion to replace it with a remanned this is a good option both mechanically and financially!
I don't know if these engines are externally balanced, if they are I would take the remanned balancer along with the old and the chipped to a reputable Automotive Machine shop that does balancing and ask them to compare the new to the old.
Wikipedia over view of a Harmonic Balancer Click here.
Just my 2 cents.
dave
Old May 2, 2013 | 12:34 PM
jagiam's Avatar
Hi,what does the harmonic balancer do if its no good, does it make a noise.Thanks.Grant.
LnrB
Oct 13, 2015 12:45 AM
jonahjob
Oct 1, 2015 07:54 AM
AnD3rew
Sep 26, 2015 06:06 PM
Dicque
Sep 12, 2015 10:34 AM
