Chirps and squeaks- What should I buy?
Old May 30, 2018 | 08:30 AM
giandanielxk8's Avatar
Default Chirps and squeaks- What should I buy?
I have a few dumb questions.
My XKR has developed a chirp on cold startup at 66k miles, it disappears after about 10 minutes of driving. However, I can also hear a squeak at about 4k rpm. I decided I am going to change the serpentine belt with the idler pulley and tensioner pulley. Should I change the belt tensioner as well? Does the 4.2 Supercharged engine use the same serpentine belt as the 4.0 N/A? What about the Supercharger belt and pulley, should I change that as well?
Looking in Rockauto, I can't tell which belt is for the supercharger and which one is the drive belt. The Goodyear Gatorbacks are now sold as Continental Elite Poly-V.
Old May 30, 2018 | 09:09 AM
Is this the correct drive belt? https://www.rockauto.com/en/moreinfo...303&cc=1425844
Supercharger belt? https://www.rockauto.com/en/moreinfo...166&cc=1425844
Tensioner pulley? https://www.rockauto.com/en/moreinfo...955&cc=1425844
Idler pulley? https://www.rockauto.com/en/moreinfo...394&cc=1425844
I can't find the supercharger pulley. Also, after searching in the forum I now have a new question. Do I really need to remove the radiator hoses?
Old May 30, 2018 | 11:37 AM
avern1's Avatar
With the hood in the "service position" you can change the belts and pulleys without removing the upper hoses. It is tight but very doable.
Old May 30, 2018 | 03:54 PM
Johnken's Avatar
I bet is is the idler pulley, sounds like the same thing I had once. Don't forget you can test that by slacking the belt and turning the idler pulley by hand. If she feels anything but smooth , replace her.
John
Old May 31, 2018 | 10:05 AM
JimmyL's Avatar
Loosen the belt pulley bolts before you take the belt off. It makes it a lot easier (Doh, been there).
nickthelimey
May 27, 2013 10:17 AM
quaker13
Feb 28, 2012 01:07 PM
cbras9
Sep 23, 2011 04:16 PM
Catwoman
May 5, 2011 09:12 AM
whitbyxf
Sep 21, 2010 02:19 PM
