Cigarette lighter install
Old May 18, 2016 | 09:17 PM
Salu498's Avatar
Default Cigarette lighter install
As stated before, my 2006 XK8 has no lighter, just the hole with no wires visible or that I can feel. Is it likely that there is the lighter wiring under the console?
If there is likely no wiring I do not want to go to the trouble of taking off the console cover. I m a novice at such things.
Also if I can't install a lighter because of lack of wiring, are there any suggestions for making use of the hole?
Old May 19, 2016 | 02:20 AM
bladerunner919's Avatar
Well, the wiring will be there unless someone has previously done some modifications. The centre console takes about 5 minutes to get off, so you're not really going to need to invest much effort in having a look.
Salu498
May 2, 2016 08:44 PM
Salu498
Apr 30, 2016 01:30 PM
brinny
Apr 30, 2016 01:56 AM
uncle jim
Apr 26, 2016 01:58 PM
Salu498
Apr 22, 2016 06:36 PM
