clearing ABS codes
Old Mar 12, 2018 | 09:54 AM
alanroberts50's Avatar
Default clearing ABS codes
I may have an old ABS code sitting in OBD memory due to a bad battery that i replaced a while back. P1000 refuses to change to P1111. My question is will holding the battery terminals together clear ALL old codes and if so, how long do they have to be together?
Old Mar 12, 2018 | 10:08 AM
fmertz's Avatar
This is because one of the OBD monitors is not reaching completion. You can get an OBD tool to figure out which one. A cheap eBay/Amazon ELM327 would do this. On my car, the components monitor takes for ever to complete. The right answer is to look up the drive cycle and execute all the steps, but most of us just drive around for however long and hope all the steps are eventually hit and the monitors complete. If the monitor does not reach a positive conclusion, then you would get other (standard) OBD codes, specific to the problem.
In other words, I do not believe ABS codes are involved in this P1000/P1111 logic.
Best of luck, keep us posted.
Old Mar 12, 2018 | 03:19 PM
scottatl's Avatar
The drive cycle is a pain to complete. Do you need an emissions test soon, or why is this an issue.
Old Mar 12, 2018 | 06:45 PM
JagV8's Avatar
A hard reset will not generally clear codes. Not ABS, not (put module name here).
Old Mar 12, 2018 | 10:22 PM
I do have to get a test and so far Ive driven 350 miles since the reset to P1000
Old Mar 13, 2018 | 01:28 PM
scottatl's Avatar
it is not just about distance, you have to drive under a bunch of conditions. I don't have the requirements but at one point I did find them on this forum or via Google.
Old Mar 13, 2018 | 01:41 PM
fmertz's Avatar
AFAIK, the drive cycle is standard. Here is one:
drivecycleford
Even better: jaguar-drive-cycle
Old Mar 13, 2018 | 11:34 PM
Thank you guys, I sure hope it clears soon!
Old Mar 14, 2018 | 10:58 AM
JagV8's Avatar
Usually when it takes too long it's due to a problem. If all else fails post which monitors are not happy. And check fuel trims.
rtdbuild
May 11, 2016 05:26 PM
K.Westra
May 3, 2012 07:44 PM
ervinj2003
Mar 6, 2012 04:09 PM
01s-type1984
Dec 4, 2011 09:52 AM
conipc
May 19, 2008 08:10 AM
