Click from front of engine
I hear a random hard metallic click, bit like a hammer striking steel, at the front of the engine which I assume to be the VVT solenoid(s). My question is should they make this noise? If not what's likely to be amiss?
Shine a bright light on the accessory drive belt tensioner and observe whether it snaps back and forth when the hammer noise occurs. If it is, your belt idler pulley bearing is probably bad, or the tensioner idler pulley bearing is bad.
BrentGardner
29
Dec 16, 2024 12:13 AM
philwarner
Dec 6, 2021 07:13 AM
Fraser Mitchell
Oct 1, 2015 04:06 AM
SingBlueSilver
Aug 27, 2015 02:20 PM
