Climate Control LED bulbs?
Old Dec 10, 2014 | 11:08 AM
Leaper_Man's Avatar
Default Climate Control LED bulbs?
Since I have to remove the center console anyway, I figured I would replace the bulbs in the Climate Control. The left one (under the fan speed indicator) is out.
I have read MANY articles on the forum, but still do not have a clear idea which bulbs to order.
It appears they are a "neo-wedge" style. however there are quite a few sizes and styles. I'd like to find the correct one.
For example:
6x Blue T5/T4.7 Neo Wedge LED Bulb Cluster Instrument Dash Climate Base Lights
These are blue. I believe I have the blue covers over the existing bulbs, but I won't know till I disassemble the console.
Also, will these DIM?? If not, I would prefer the original bulbs. NOT from a dealer...not at 7USD a piece!
Help!
Rich
Old Dec 15, 2014 | 01:05 PM
Leaper_Man's Avatar
Wow...is no one interested in using LEDs in their climate control head or instruments?
Hard to believe.
Rich
Old Dec 15, 2014 | 01:09 PM
Gus's Avatar
Gus
How many for that price? I have one out and need to replace it.
Old Dec 15, 2014 | 02:13 PM
Richxk8's Avatar
I just had to replace a couple of bulb's.
Here is a good source.
Instrument Panel Gauge Dashboard Colored Led Bulbs Lights Lamps
Old Dec 16, 2014 | 06:34 AM
jamdmyers's Avatar
Hard to believe.
Rich
There are some threads on this, Rev Sam had posted he put in LEDS but then ended up taking them back out because it didn't provide enough illumination. Note sure of any specs without looking them up, Voltage/current on whether you could put a higher lumen bulbs in.
Old Dec 16, 2014 | 07:14 AM
Leaper_Man's Avatar
I have multiple sources for neo wedge bulbs in many output levels and colors. just need to know which SIZE!
Rich
Old Dec 16, 2014 | 01:09 PM
tsuppari's Avatar
I used T4 neo wedge SMD Led bulbs to replace climate control temperature display background illumination bulbs.
Works ok, but it should be noted that SMD bulbs do not spread light as traditional ones so middle part of display is quite bit darker than edges.
Anyway for $7 I got 4 SMD leds so I can live with that.
Also If I recall right installation of SMD leds must be so that current is right i.e. +->+ and - -> -, otherwise it won't illuminate.
Chris Hinton
Sep 24, 2015 08:38 PM
kenatofc
Sep 22, 2015 12:45 PM
dstary
Sep 19, 2015 09:47 AM
texaspete
Sep 10, 2015 08:34 AM
tberg
Sep 7, 2015 07:32 AM
