Code P0741 and fuel at less than 3/4 full
Old Mar 22, 2015 | 01:34 PM
mikey59's Avatar
Default Code P0741 and fuel at less than 3/4 full
I get the P0741 code only when my gas tank is less than 3/4 full. Fill up the tank and the code and the check engine light goes off. Comes back on when the tank is less than 3/4 full.
Any idea what is wrong?
Mikey59
Old Mar 23, 2015 | 06:30 AM
jamdmyers's Avatar
Are you sure it was 0741 and that was the only one ?
Old Mar 23, 2015 | 08:01 AM
mikey59's Avatar
The codes were
0741
1111
0741
Old Mar 23, 2015 | 08:38 AM
test point's Avatar
Strange! P0741 has nothing to do with fuel and is reporting a torque converter problem. The P1111 is an indicator that everything is OK and it is strange to have it along with a code.
Any issues with transmission or shifting?
Here is the JTIS list for P0741:
File Type: pdf
Old Mar 23, 2015 | 11:40 AM
mikey59's Avatar
the transmission was rebuilt a couple of years ago and no issues there. When my mechanic fixed a coolant leak he said he fixed a loose sensor/check engine light. Maybe it is loose again?
Old Mar 23, 2015 | 03:15 PM
jamdmyers's Avatar
Odd since TP was correct that this is a trans code(that's why I asked for confirmation), nothing to do with fuel etc, you might try letting the tank get to about 1/2 then throw #100 in the trunk and see if it goes away, adding gas is only adding wight (there are some emission issues but you're not seeing them). Might shed more light on your issue.
toronadomike
Jan 22, 2026 10:13 PM
Bcrary3
Feb 21, 2023 04:29 AM
ccfulton
Sep 20, 2015 05:15 PM
OkieTim
Sep 8, 2015 04:48 PM
hen555
Sep 7, 2015 11:13 PM
