Code RED: P0020 - RESOLVED
Old May 19, 2013 | 10:46 AM
Mike Graham's Avatar
Default Code RED: P0020 - RESOLVED
Hi,
I have a check engine code P0020 and I can't find where there is a list of Jaguar XK8 codes, so on Google (generic) it says cam position sensor or VVT, PCM or OCV. Can someone help narrow this down or is there a Jaguar XK8 P0020? I couldn't find one.
Thanks in advance.
Mike
Old May 19, 2013 | 10:54 AM
chopr's Avatar
P0020 Intake Camshaft Position Actuator
Most of the time, this code will throw due to a lack of oil pressure to the VVT unit. Have you recently changed your oil? These cars can be sensitive to oil that is not regularly changed, or putting the incorrect weight of oil when servicing. You may just need to change your oil and reset the code to see if it returns. That's the "good side" of things. On the bad side, you may have a faulty VVT solenoid, or a blocked oil port requiring removal of the front cover to repair. You can operate the solenoid by unplugging the connector and "jumping the solenoid using a 12 volt source, and listening for a click... indicating that it is trying to work. Just my two cents!
Last edited by chopr; May 19, 2013 at 10:56 AM. Reason: Unclear recommendation! The solenoid can be replaced by removing the valve cover. "A" bank is typically the "right" side.
Old May 19, 2013 | 11:24 AM
steveinfrance's Avatar
Worth checking the B bank VVT solenoid connector.
Old May 20, 2013 | 10:25 PM
chopr's Avatar
One more tidbit: If you energize each solenoid while the engine is running, there will be a detectible difference in the engine smoothness after about 5 seconds, if the solenoid is doing it's job and the oil is getting to the vvt. It's is possible for all to "sound good", ie a "clicking noise", but the vvt solenoid may still not be working. After comparing one that worked with one that didn't, I can see a difference in the basic pintle location in the valve. Both clicked strongly. I had an XJ8 in the shop like this just today.
Old May 25, 2013 | 09:22 AM
Default Code Red Thanks
Thanks to all for your imput. I traced the problem to dirty contacts, (may have been loose too) I cleaned them, then greased with dielectric grease and reconnected, the world is beautiful again.
philwarner
Oct 4, 2024 01:37 PM
danke
May 29, 2023 01:01 PM
RickyJay52
Sep 20, 2021 04:48 AM
philwarner
25
Jun 26, 2021 05:43 AM
KarimPA
Sep 27, 2015 08:46 AM
