Collapsing radiator hose
Old Oct 12, 2011 | 06:12 PM
gchin's Avatar
Default Collapsing radiator hose
After the engine is cooled overnight, the top front radiator hose partially collapses.
I read some forums about the issue, so I removed and replaced the coolant recovery tank cap with a new one. The hose still partially collapses.
Does anyone else have that problem or a solution?
Photo attached.
Gary
Old Oct 12, 2011 | 07:22 PM
oldmots's Avatar
The cooling system is pulling a vacuum when it cools and the coolant contracts. The problem is, what is letting a vacuum occur. Normally, as teh colant cools down, it contracts, creating a suction that pulls coolant from the recovery tank through the radiato cap suciton valve. The coolant recovery line may be plugged or kinked, the radiator hose may be old or weakened, the radiator cap suction valve may be inop.
Old Oct 12, 2011 | 07:36 PM
jam1white's Avatar
I had the same problem...it was the thermastat sticking. I replaced it and all good. Another indicator is that my fans were coming on a lot after i turned the car off.
Old Oct 13, 2011 | 10:47 AM
stevepaa's Avatar
I'd also replace the hose while you do the thermostat and check the flow of fluid to the overflow tank in the fender.
Old Oct 13, 2011 | 11:04 AM
GordoCatCar's Avatar
Make sure it is installed correctly. Mine collapsed, cut off flow, and I could not figure out why until I realized the last person to install it, put it on wrong. I switched ends, and everything has been OK for the last 5k miles. go figure.
Old Oct 13, 2011 | 11:13 AM
Gus's Avatar
Gus
Does anyone know if the cap has a check valve in it that will release the vacuum?
Old Oct 18, 2011 | 09:42 PM
gchin's Avatar
The latest seems that the radiator hose going to the thermostat tower is weak. When the engine is hot, the hose appears to bulge. When the engine is cold, the hose partially collapses. The vacuum is supposed to suck the cold coolant from the recovery tank, through the overflow tank, back into that radiator hose.
Old Oct 18, 2011 | 10:02 PM
If you think the hose is weak, then buy another. However, I suggest you first insure it is mounted correctly on your car. See my post above. gordo
Old Oct 19, 2011 | 10:18 PM
H20boy's Avatar
they will weaken, even mine showed a bulge after only 7 years. Replace and sleep well.
Old Oct 22, 2011 | 11:09 PM
jimrxk8's Avatar
Ditto H2Oboy's comment. Mine would collapse when cold, and bulge when hot (to the point of actually making contact with the fan shroud reforcing splines). Had it replaced last week....no more collapsing or bulging.
Old Oct 23, 2011 | 01:12 PM
gchin's Avatar
Got the weak lower radiator hose removed and replaced.
No more collapsing or bulging.
Thank you to everyone on this forum!
Old Oct 23, 2011 | 07:06 PM
Gus's Avatar
Gus
I think you will find the reason for the collapsed hoses is a malfunctioning reservoir cap. The reservoir cap serves two functions pressure and vacuum relief.
Old Oct 23, 2011 | 11:29 PM
H20boy's Avatar
The hose replacement job is a good way to get familiar with your engine bay w/o getting into anything too complex, consider it a stepping stone to other, more complicated projects like coil-on-plug, or valve cover gasket changes, idler and tensioner pulley, etc.
How was that little short stubby hose that actually paired up to the thermo-tower? Was it soft or showing signs of bulging? it is also something that can blow pretty easily if left unchecked. Its hard to tell from the picture.
mikiep
Dec 20, 2019 07:37 PM
vwbusbits
Oct 13, 2015 03:43 AM
inactualis
Oct 2, 2015 11:13 AM
Johncy2000
Oct 2, 2015 01:05 AM
Lubrication
Oct 1, 2015 03:56 AM
