Compatible Lincoln suspension components?
Old Aug 25, 2020 | 07:52 PM
XKHawk's Avatar
Default Compatible Lincoln suspension components?
In my first few months of ownership of my 2002 XK8 convertible I have replaced a broken driver side mirror and the front shocks and shock tower mounts. I am now looking at the upper and lower control arm items - bushings/ball joints/etc.
I've done a little searching on the site (admittedly not a ton), just not finding much specific - is there a little cheat sheet of compatible Lincoln (or gasp...even Ford) parts for these cars?
Thanks in advance for any feedback I can gather!
Old Aug 25, 2020 | 08:41 PM
not sure about Lincoln/Ford but try the forum sponsors who most give forum members discounts. you can also find good deals from Rock Auto and Parts Geek. You do not need to buy control arms - all bushings & ball joints can be replaced although the lower ball joints are quite the PITA. If you want poly bushings - powerflex is a good choice. There is also a sticky at the top of this forum for alternative parts - may find some info there
Old Aug 25, 2020 | 09:04 PM
XKHawk's Avatar
Thanks for the reply, I'll check out the sponsor and alternative parts threads.
I already have upper ball joints purchased from Rock Auto and am about to buy at least the upper control arm power flex bushings, probably the front sway bar bushings as well.
I'm just looking at other future maintenance items/upgrades and wondering what all the options may be out there.
Old Aug 25, 2020 | 09:35 PM
xalty's Avatar
Zero (0) suspension parts crossover with other FoMoCo cars.
Very few select engine parts (misc. seals, secondary tensioners, oil filter) cross over from the Lima 3.9 to the AJ28 4.0.
swrichar
Aug 15, 2020 01:17 AM
JCalhoun
Mar 26, 2020 09:21 PM
swrichar
Nov 6, 2018 02:34 PM
Supersport6
Jul 13, 2015 10:27 PM
chazaroo
Nov 27, 2010 06:09 AM
