Compression check
Old Sep 18, 2012 | 11:19 PM
Mendo XK's Avatar
Exclamation Compression check
What is the proper way to check the Cylinder Compression.
Old Sep 20, 2012 | 07:25 AM
Jag13cat's Avatar
Default Compression Check
Based on my information:
After bringing engine to operating temperature:
Disable ignition system from firing
Disable fuel system from delivering fuel
Prop throttle body wide open
Thread compression gauge into each cylinder and crank engine approx.
5-6 revolutions to attain reading - record each cylinder reading
(I mention threaded compression gauge vs the rubber tip hold in gauge for a more accurate reading)
Upon completion, you may encounter a number of fault codes that must be cleared
bamforp
Aug 14, 2024 05:36 PM
mrplow58
Jan 21, 2024 05:53 AM
chatmanx
Sep 11, 2015 07:17 PM
bavareze
Sep 11, 2015 01:49 AM
corysansburn
Sep 10, 2015 06:15 AM
