Convertible Latch Leaking
Old Jul 21, 2015 | 04:22 AM
Jim 2001 XK8's Avatar
Default Convertible Latch Leaking
I went to put top down and hydraulic fluid began pouring out of head panel below where the top latch is.
Note: I was picking the car up from the body shop after having the nose repainted.
Any ideas as to what I'm in for in terms of repair.
Old Jul 21, 2015 | 05:30 AM
<p>Most likely the hoses have deteriorated and will need replaced. &nbsp;It can be done DIY or farmed out to local indie. &nbsp;If the latch hoses are bad, check the RAM hoses as well. &nbsp;If the outer black layer is flaking off the hoses - recommend replacing all at once. &nbsp;</p><p>A complete set of hoses is around $600. &nbsp;I used Cabriolet Hydraulics when I replaced&nbsp;mine, Top Hydraulics is also a recommended vendor.</p><p>Take a look at Gus's website (link below) for procedures on replacing</p><p>JagRepair.com - Jaguar Repair Information Resource</p><p>If your lucky, you may have another member in your area that has experienced this phenomenon and would be willing to assist for a cold beverage or two.</p><p>regards,</p><p>Steve</p>
Old Jul 21, 2015 | 07:39 AM
regger21's Avatar
Don't be intimidated if you decide to swap the hoses and cylinders yourself. Lots of pieces but it's fairly straightforward and there are lots of good photos on the forum. I did mine in the spring and it all went smoothly. I also put in Gus's relief valve for some extra piece of mind.
Good Luck!
Randy
99xk8guy
Sep 29, 2025 10:51 PM
99xk8guy
May 28, 2024 09:36 PM
Rivguy
Dec 4, 2020 07:55 AM
Jay48
Sep 7, 2015 09:30 PM
rachelstr
Sep 3, 2015 12:59 PM
