Convertible top hydraulic flush
Old Jul 7, 2020 | 06:59 AM
Oldelance's Avatar
Default Convertible top hydraulic flush
What is the process to flush hydraulic lines on my convertible top. 2004 xk8. Thanks for help.
Old Jul 7, 2020 | 08:04 AM
Dennis07's Avatar
May I ask why you want to do this? Generally not required.
Old Jul 7, 2020 | 12:18 PM
Johnken's Avatar
Dennis has a good question.
OP: there is a TSB about replacing the fluid on earlier models, pre 1999 as I recall, that came with fluid that coagulated causing slow performance. It addresses fluid replacement. I don't have time to find it 4u today,sorry .
John
Old Jul 7, 2020 | 09:03 PM
DavidYau's Avatar
Firstly, I'm probably guilty of pursuading Oldelance to change the hydraulic fluid, as in my extreme heat environment in Bahrain, I've changed mine. I didn't "flush", just changed the fluid in the tank.
In my case, just removed the pump's bottom fittings and tilted the pump tipping the fluid out of the brass fitting in the top. After running the top a few times, a week later, I did it again.
Just make sure you have quality hydraulic fluid. Here's what I used. Came with the replacement hoses from British Parts.
Old Jul 7, 2020 | 11:24 PM
Johnken's Avatar
FYI found the TSB. Its 501-33 in case it helps anyone.
John
Old Jul 8, 2020 | 01:43 AM
DavidYau's Avatar
Default Link to TSB 501-33 in stickies
Thanks Johnken,
Here’s a link to the TSB in the Stickies. Makes interesting reading reg. earlier bad hydraulic fluid used.
https://www.jaguarforums.com/forum/x...34/#post198058
Dennis07
Aug 13, 2020 08:40 PM
Oldelance
Jul 6, 2020 04:11 AM
superchargedtr6
XK120 XK140 XK150
Apr 18, 2020 07:52 PM
lonejag
Jun 19, 2018 12:48 PM
