Convertible top Window problems
Old Aug 2, 2014 | 12:45 PM
bvpusa's Avatar
Default Convertible top Window problems
When I activate down button the back windows go down, but the side windows stop half way. The top goes down ok and I can get side windows down with door buttons.
All was ok until I removed drivers seat to try and fix airbag 2-2 flashing. Cleaned connectors reinstalled but light still on and now the top deal??
Any ideas? Thanks Ken
Old Aug 2, 2014 | 03:07 PM
BlkCat's Avatar
Ken, it sounds like the window has lost its "memory". To reset the memory hold the button raising the window until you hear a faint click a few seconds after the window is closed. Then lower the window. Again, hold the down switch for a few seconds after the window is fully down. Until you hear that faint click again. The memory is now set.
Then try lowering your roof again and see if all is well.
Jack
Old Aug 4, 2014 | 01:53 PM
bvpusa's Avatar
BlkCat, You are Right On! Thanks Now If I can only get the airbag light to turn off. It flashes 2-2 then stays on. I removed drivers seat and checked connection under seat, but all looked ok. And light still on?
But Thanks for the window problem solved. Ken
Old Aug 4, 2014 | 03:18 PM
Jandreu's Avatar
Check the number 10 fuse in the left drivers side. Top left fuse, should have a yellow cover on it. If it's blown the yellow airbag light will stay on.
Old Aug 5, 2014 | 01:49 AM
azeteg's Avatar
Pages 70-82 of this document should help you to diagnose and correct LFC 22.
Good luck!
msdg137
Sep 16, 2015 06:24 AM
reedmtn
Sep 5, 2015 08:04 AM
24ktairman
Aug 30, 2015 10:25 PM
reedmtn
Aug 30, 2015 08:28 AM
Jandreu
Aug 29, 2015 07:31 PM
