Convertible window control
Old Feb 17, 2011 | 12:35 PM
EZDriver's Avatar
Smile Convertible window control
After not driving my 2000 XK8 during all the cold weather here in East Texas my automatic function of the windows on this convertible is not working correctly. When I open the door with the windows up they lower slightly (so far so good). When I close the door the window does not go back up and then pop down slightly like it is supposed to do. When you open it again the window drops again a small amount. If you continue to open and close the door the window will continue to lower a small amount until it is eventually all the way down. Both windows malfunction the same way. If you lower the top with the windows up they really act up. When the top is half way down the windows (both) will bounce up and down real fast for about three cycles.
I am desperate to fix this, but don't even know where the control module for this function is.
NEED HELP.
EZDriver 2000 XK8 1995 XJ6
Old Feb 17, 2011 | 12:41 PM
bassmania's Avatar
Default Check out this link: Window problems.
Hello EZDriver 2000 XK8 1995 XJ6 ,
Go to https://www.jaguarforums.com/forum/s...ad.php?t=49897 . There was a thread concerning your issue. Hope this helps.
Bassmania
Old Feb 17, 2011 | 12:51 PM
EZDriver's Avatar
Thanks for the very, and I mean very quick response. I will do as you suggest.
Thanks again Bassmania.
EZDriver
kj07xk
Dec 18, 2025 10:56 AM
99xk8guy
Sep 29, 2025 10:51 PM
99xk8guy
May 28, 2024 09:36 PM
GordoCatCar
Jan 2, 2017 01:10 PM
sadepol01
Sep 11, 2015 05:26 AM
