Coolant Color Mystery
Old Dec 28, 2011 | 06:18 PM
Skid Mark's Avatar
Default Coolant Color Mystery
I read one of the recent threads on the yellows, greens and oranges of modern day coolants, and read where someone suggested to take a paper towel and dip in it the resevoir to find your true color. So, driving a 2002 XK8, I assumed mine would come up green probably, based on what I read, or possibily yellow, since that's what the color looks like in the resevoir, but I got...
Orange??? Does orange coolant and a black resevoir make for yellow looking coolant?
Should I chemical flush, and replace with something green, or yellow, or just run with it, or what?
I'm so confused.
Old Dec 28, 2011 | 07:37 PM
Paul Pavlik's Avatar
Orange is the color of the OAT Long Life Coolant specified for my 2000 XKR. I believe that your car uses the same. There is a spec number on the Coolant Reservoir Cap. A Auto Parts Store will have Coolant that meets that Spec.
Old Dec 28, 2011 | 08:39 PM
Skid Mark's Avatar
I went out and looked and you're right. It says WSS-M97B44-D (ORANGE) right on top of the resevoir. Motorcraft makes an orange coolant that meets that spec, guess I'll get some of that.
I'm guessing that the two or three ounces of yellow coolant I topped it off with a few days ago won't cause some kind of wicked chain reaction with the orange and wreck the engine.
Thanks, Paul.
Old Dec 28, 2011 | 09:32 PM
Count_Damonee's Avatar
"I'm guessing that the two or three ounces of yellow coolant I topped it off with a few days ago won't cause some kind of wicked chain reaction with the orange and wreck the engine."
You should be fine,,, most of the Coolants are interchangeable...
However make sure that they are the same type as in Propylene Glycol to Propylene Glycol
and Ethylene Glycol to Ethylene Glycol
Apparently as the "Old Wives tale Goes" if they are mixed there is a possiblity of a chemical reaction that will cause the liquids to coagulate... And if there are 2 things that scare me IT'S - OLD WIVES AND RUINED ENGINES,,,
Disclaimer- I am not a Chemist,,, But I did Sleep at a HOLIDAY EXPRESS last night...
That being said,,, Here's the facts on Anti-Freeze / Anti-Boil (The anti-boil part is for us Southern boys)LOL...
The major use of ethylene glycol is as an automotive antifreeze. Due to its low freezing point, it is also used as a deicing fluid for windshields and aircraft. Ethylene glycol is also commonly used in chilled water air conditioning systems that place either the chiller or air handlers outside, or systems that must cool below the freezing temperature of water.
Ethylene glycol has become increasingly important in the plastics industry for the manufacture of polyester fibers and resins, including polyethylene terephthalate, which is used to make plastic bottles for soft drinks. The rapidly expanding economies of China and India have led a worldwide increase in demand for ethylene glycol, and have helped to fuel recent price increases.
The antifreeze capabilities of ethylene glycol allow it to be used for airplane deicing and have made it an important component of vitrification mixtures for low-temperature preservation of biological tissues and organs.
Obviously, the purity requirements for soft drink bottles, deicing and preservation of biological tissues is much greater that it needs to be for automotive antifreeze or chiller fluid, and virgin EG is required for those applications.
Automotive antifreeze/coolant is made of ethylene glycol, water, and a chemical additive package. For many years, there was only one type of antifreeze on the market, conventional green. Antifreeze technology, however, has become significantly more complex in the last several years with the introduction of Dexcool and other extended life antifreeze formulas. There are three main types of antifreeze on the market. They all contain an ethylene glycol base, water, dye and an additive package. Colored dye is added for leak detection and is not a reliable way of identifying coolant type. The additive package is what makes them different.
Conventional green antifreeze formulations usually contain a number of inorganic corrosion inhibitors that provide immediate corrosion protection because they maintain the pH of the solution (buffer it), but are consumed or transformed chemically as they perform their functions. As the coolant is heated and cooled, and exposed to air, the components of the conventional antifreeze additive package are depleted over time. This causes the pH to drop, and is why the coolant should be changed out every two years or 24,000 miles.
Dexcool-type extended life coolants use organic acid technology to inhibit corrosion, and are referred to as OAT based coolants. OAT antifreezes are touted as having longer potential service life than conventional antifreezes because of the fact that the components in the additive package are not chemically consumed as they perform their function of inhibiting corrosion. The chemicals used in the OAT type formulas protect metals from corrosion by forming a thin, molecular coating on them, and because of this, are not as fast acting as conventional inorganic formulas. However, as long as the cooling system is kept sufficiently full and coolant is not lost due to leakage nor diluted by top-off with water or conventional antifreeze, it will continue to function properly. Unfortunately, if the cooling system is not properly maintained, a “red muck” is likely to form and could cause serious cooling system problems.
The third type of antifreeze on the market today is the hybrid OAT, known as HOAT (or G O-5). One of the primary problems with OAT formulations is that they are not compatible with conventional antifreezes. The chemicals used in OAT antifreeze react to some extent with some of the inorganic salts and other components in conventional antifreeze. The result of this interaction is the generation of cloudiness and precipitates. HOAT formulations are called hybrid because the additive package contains ingredients from both OAT and conventional formulas and is compatible with both.
Hybrid OAT antifreezes provide both fast acting and extended life corrosion protection, eliminate the problem of anti- freeze compatibility, and therefore are compatible with all types and colors of antifreeze.
Unfortunately, many automotive professionals consider all extended life antifreeze to be “Dexcool” and associate all the problems related to “Dexcool” with both OAT and HOAT formulas. The result of this misconception is often replacing the extended life coolant with conventional green. Industry experts say that this can be done safely if all of the green antifreeze is removed from the system. However, auto manufacturers recommend specific formulations and replacing the factory fill coolant with a different type that doesn’t meet the manufacturer’s specifications could cause liability issues down the road. A much safer solution is to replace OAT systems with HOAT coolant which meets OAT specifications.
Regardless of the type of antifreeze used, the additive package will eventually break down and cease to provide adequate corrosion protection. The antifreeze will also pick up contaminants from the engine cooling system. In other words, antifreeze wears out and gets dirty. The service life for conventional green antifreeze is 2 years or 24,000 miles, and for OAT and HOAT is 5 years or 150,000 miles, and the manufacturers recommend fluid replacement at these intervals. However, although the antifreeze loses its corrosion protection and picks up contaminants, the ethylene glycol base does not break down and remains intact. In other words, the ethylene glycol retains its ability to lower the freeze point and raise the boiling point of the solution. This simple fact is the basis for the antifreeze recycling industry.
AND NOW YOU KNOW ALL THERE IS TO KNOW ABOUT COOLANT... I think...
Old Dec 28, 2011 | 09:46 PM
Skid Mark's Avatar
Yes, they're both Ethylene Glycol according to the Motorcraft website. That was a good point. Thanks, Count!
Old Dec 28, 2011 | 09:50 PM
No Problem,,,
Old Dec 28, 2011 | 11:55 PM
Languid's Avatar
Thanks, Count, exceptionally informative
Languid
Old Dec 29, 2011 | 03:52 PM
Dennis07's Avatar
Default G-05 experience
I should start by admitting that I once tried to understand the details of the OAT / HOAT coolants ... and the effects of OAT on this or that cooling system component ... or the effects of HOAT on some other component. Bad idea; in the end, I gave it up. When you start peeling back this particular onion, there are many layers, and no shortage of opinions.
So let me just report my experience. My '01 XK8 was new to me in the fall of '06. What coolant was in there, I dunno, but the Jag-recommended coolant for that MY turned out to meet the dexcool spec (OAT). Anyway, there were rumors around at that time about dexcool clogging up some cooling systems (GM, not Jaguar, as I recall) AND I found some sort of condensate sloshing around in the coolant tank. Both of these things made me nervous, so I flushed everything a few times and switched to G-05 (HOAT).
Five years on, the only thing I'm sure of is that if the G-05 is causing any problems, they must be very slow to develop. Also, there's no sign of any condensate in the coolant.
FWIW.
Old Dec 29, 2011 | 04:17 PM
Spurlee's Avatar
Default Any color...
The Prestone coolant I bought the other day says it can be mixed with "any color coolant". It is yellow. I used it to top off my old truck and 2000 Jaguar without concern.
The Dexcool that was OEM in my Corvette is orange. I keep it that way and don't mix brands in that car.
trosty
Jan 8, 2016 06:43 PM
duecedriver
Dec 25, 2015 11:47 AM
Steve10
Sep 20, 2015 12:27 PM
