Coolant leak, resolved
Old Oct 1, 2013 | 09:37 AM
oyster's Avatar
Default Coolant leak, resolved
Hi.
I have had a small coolant leak for some time not from the usual places, so I decided to take things apart to investigate.
Here is what I found:
Previous owner had changed the clip on the thermostat outlet to a worm clip or also called a jubilee clip. The clip has been tightened to much deforming the outlet as you can see in picture 1.
This deformation also made a small gap between thermostat cover and water tower giving the leak. Picture 2.
Changed to aluminium water tower and thermostat cover which solved the problem.
Attached Thumbnails Coolant leak, resolved-20131001_160035.jpg   Coolant leak, resolved-20131001_160144.jpg
arskemp
Sep 21, 2015 02:19 PM
Lannyl81
Sep 19, 2015 08:07 PM
OkieTim
Sep 8, 2015 04:48 PM
Xkr x100
Sep 6, 2015 08:50 AM
OkieTim
Sep 2, 2015 12:48 PM
