Coolant level sensor pigtail
Old May 22, 2012 | 02:15 PM
MRomanik's Avatar
Veteran: Air Force
Default Coolant level sensor pigtail
I replaced the coolant level sensor and noticed that the connector (pigtail) did not have a metal clip on it like many of the others do. Any way to fix this without buying another connector?
Thanks.
Old May 22, 2012 | 04:54 PM
test point's Avatar
My sensor ends in a connector with male connectors inside a female housing which matches the connector on the leads to the car. Not sure I follow your description. Could you post a picture?
Old May 22, 2012 | 09:07 PM
MRomanik's Avatar
Veteran: Air Force
sorry the pic is crappy. The connector with the clip is on the brake reservoir.you have to press the clip to take off the connector.
the coolant level sensor connector doesn't have a clip.
File Type: pdf
Old May 23, 2012 | 02:06 AM
test point's Avatar
Mine doesn't either. Maybe the Jaguar design thought is that if the connection comes loose you will take it to a dealer for repair without involving any safety issues . . . or we both have defective connectors.
mrplow58
Jan 21, 2024 05:53 AM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
KarimPA
Sep 12, 2015 08:15 AM
JimMLiny
Sep 9, 2015 08:13 PM
KarimPA
Sep 3, 2015 07:32 PM
