Coolest - most important upgrades
Was curious what y'all thought was the first things to be done..
I'm thinking new suspension parts and/or Brembos... as most the other parts are in great condition.
But would like to hear your thoughts.
DJ
DJ
of all the 'modifications' that i've done to my xk8, my top five would be:
1. WhiteXKR's convertible top module (opens/closes the top with your key fob)
2. throttle cable adjustment (and its free!) See FAQ
3. X-pipe in place of the center muffler (plus some new exhaust tips)
4. Tbirddmnd's replacement hood liner Hoodliners.net
5. XKR grille swap
5. XKR grille swap
All good suggestions so far.
While you are on WhiteXKR's site TheJagWrangler - Home - About Us check out his RealGauge product. Not a high wow factor for passengers, but very cool for the driver.
Modifying the side lights/leaper badges is a simple quick update as well.
Slightly left-field, I wired one of these into my old car's ECU:
Still have the bits, is it be easy to get at the ECU looms etc to do the same for my XKR? It's a Defi HUD: the screen detaches and you can put a film on the windscreen if you prefer.
Best wishes, Colin
Best wishes, Colin
Replace catalytic converters. Since you're in CA, you would have to risk not passing smog. I don't have to re-smog yet, but I'll certainly post results when I have to do mine.
Replace the over the axle bend in the muffler tube.
Avos' twin screw kit (if you have an R)
on/off switch for antenna
remote top mod
remote top mod
Do not forget the XK8/R forum now has a modiification section: https://www.jaguarforums.com/forum/x...cements-86088/
Collin, that is a VERY cool HUD, let us know if you get it integrated into your xkr!
Tarheal, those wheels are stock for my car, 19" called 'Apollo' by jaguar. And, thank you for the compliment.
Those are OEM 19 inch rims. I don't remember the exact name. When I have enough money, I'm gonna buy a set of those for my XK8 'vert. Does anyone know if I can have a full size spare with those rims?
The wheels are OEM Apollo style.
With that being said, do anybody here ever purchased from Wheels Rims | OEM Alloy/Steel Wheels | Wheel Covers | Lights & Mirrors - WheelsRims.net?
I found the aforementioned wheels there for $197 a piece
I'd definitelly like to hear from any members who have ever purchased anything from them and actually received alloy wheels instead of four plastic hula hoops at their front door
Link to the Apollo style rim:
Jaguar XK8 19" x 8" Alloy Wheel Sales - Buy 2003 Jaguar XK8 SILVER; 5 SPLIT SPOKES at discount price!
Damn, at that price, I might actually buy them when I get the extra money from the scholarship, but alas, the timing chain tensors are more important. I'll leave that for the next tire change, since I changed mine a few months ago, this will be far from now.
I wouldn't purchase from them, last time I tried a similar online retailer (not showing actual inventory) took my money, and then told me they'd search for the wheels I ordered, only to have them call later or me follow up after weeks w/o fulfilling my order, and i had to ask for my order cancelled and refund my payment.
Stick with ebay, https://detroitwheelandtire.com/, OEM Wheels & Rims (Factory), and https://www.allfactorywheels.com/, they are legit sellers of wheels in stock, if shown on their website or on ebay.
Thanks H20boy! I thought it's too good to be true, but there's always this what if factor...until you get burned
or bricked, hahah.
In any way, it's unreasonable to believe that they would not turn extra profit from such low availability items. Still open to hear from any member who actually received other then plastic set of rims from them
Best,
Danny
.Best,
Danny
Hope this helps ,
NikasilNik
PS Make sure it's a front wheel for a spare then it will fit all four corners , rear rims don't fit on the front of an XK
The coolest mods are rarely the most important!
If your maintenance is in check, pretty much anything WhiteXKR makes as has been said. RealGauge is the biggest one on my list for this spring, as well as disabling/replacing the antenna.
Finding an aux-input for my iPhone using the stock stereo is on my ASAP list. I'm thinking about adding a yellow EU UK plate on the back behind my standard state plate. I'm also in the process of changing my half-green/half-red badging to all red (wheel caps received, hood growler badge later this week!), and adding H&R 20mm DRM spacers later this month- will post a thread when I get these done as well as a professional detail job inside/outside (I love doing this, but am cramped for time lately). I will upgrade the wheels to 19-20" OEM+ on my next tire interval which will be another year or two.
If your maintenance is in check, pretty much anything WhiteXKR makes as has been said. RealGauge is the biggest one on my list for this spring, as well as disabling/replacing the antenna.Finding an aux-input for my iPhone using the stock stereo is on my ASAP list. I'm thinking about adding a yellow EU UK plate on the back behind my standard state plate. I'm also in the process of changing my half-green/half-red badging to all red (wheel caps received, hood growler badge later this week!), and adding H&R 20mm DRM spacers later this month- will post a thread when I get these done as well as a professional detail job inside/outside (I love doing this, but am cramped for time lately). I will upgrade the wheels to 19-20" OEM+ on my next tire interval which will be another year or two.
