Cost of oil change--Really?
Old Jan 2, 2024 | 10:50 AM
  #41
SeismicGuy's Avatar
I sort of agree but it heavily depends as well as to where you are in life. Way back when I used to love doing my own oil changes, adjusting points and carburetors (remember those things?), etc. And when I first got the 2005 XKR back in 2008 I did a couple of DIY tinkering such as fixing the headrests that were not moving, installing the pressure regulator for the convertible top (thanks Gus and Walt), and chenging instrument panel bulbs. But there gets a point where you don't mind paying someone else to service the vehicle and luckily there is a great independent shop nearby. I have one "big" job that needs doing that I have been putting off (upper shock mounts) and two small PITA things that I am tempted to tackle (antenna motor not working due probably to broken cable inside) and trunk button not working (due probably to broken wires in the bonnet to lid harness). There gets a point where, in the scheme of things, it is just easier to pay someone else to "fix" things. I find this is also the case for stuff that needs "fixing" in the house
Old Jan 2, 2024 | 04:34 PM
  #42
zray's Avatar
Originally Posted by mrplow58
Being a Porsche Audi VW tech since I was 18, I do have to say that the lowly technician doesn't get a large chunk of the dealer's hourly rate, unless of course he has proved himself worth more. I ended my career getting 40% of our flat rate time. …..”
OUCH !
I started my motorcycle mechanic career in the late 1960’s when 60-40 was the standard with the mechanic getting the 60%. I never got less than that all the way thru to the late 2000’s working in a classic car & motorcycle restoration shop. This was working in Maine, Oklahoma, Missouri, and Texas.
Z
Old Jan 2, 2024 | 05:26 PM
  #43
scardini1's Avatar
Sometimes the "expert" work we expect, when we pay for just ain't so expert. No shop, including a Jag dealer, ever properly serviced my transmission oil. One even used an off-brand fluid (Redline) that just wasn't compatible. It took me three "proper" DYI services to finally purge all of it with MERCON. And the tranny ran better than EVER afterward. Nobody cares more about your car than you do. Nobody will put the attention-to-detail into any given task than you will. Yeh - even I had to subject Kitty to a shop a couple of other times for tasks that beyond me, but I watched and was directly involved with the mechanic.
Old Jan 3, 2024 | 06:09 AM
  #44
Jon89's Avatar
^^ Agreed....
Old Jan 3, 2024 | 08:09 AM
  #45
dibbit's Avatar
Has the cost of an oil change gone up much in the 9 years since this thread was started?
Old Jan 3, 2024 | 11:22 AM
  #46
Jon89's Avatar
In my neck of the woods it certainly has....
Guildow
XE ( X760 )
Oct 15, 2021 12:19 PM
Dealersadvocate
Aug 26, 2020 09:45 PM
jimbobble
Sep 5, 2018 03:06 PM
shift
Nov 5, 2014 12:15 PM
frontrunning
Dec 12, 2011 04:21 PM
