Coupe owners – Check your door top seals !
Old Nov 8, 2024 | 07:24 PM
Hell-Cat's Avatar
Default Coupe owners – Check your door top seals !
I recently checked my door top seals, removing the rubber seal and metal gutter – it was dire under the gutter trim which is lined with a thin layer of foam rubber – this not only allows water between the gutter trim and the door glass body but harbors it and rots the trim, securing screws and body. I’m refurbishing my trims, body contact areas and the rubber seals themselves which both leak water down the dashboard ends and fuse panels.
Is this worth while writing up the refurb steps and pics to anyone ?
If you haven't checked under there recently, I strongly suggest you take a look before the rot gets into your C pillar and roof panel.
Old Nov 9, 2024 | 04:48 AM
bladerunner919's Avatar
Yes please!
Old Nov 9, 2024 | 09:50 AM
michaelh's Avatar
I had a similar problem on the RHS:
https://www.jaguarforums.com/forum/x...3/#post2501762
There's a link within to a post from ChrisHens which I found helpful.
The other side was OK so I just replaced the securing screws with SS ones.
And +1 on a writeup, please.
Old Nov 9, 2024 | 11:03 AM
Hell-Cat's Avatar
No problem, unfortunately I’m part way through the refurbishment but will document what I can.
N Bath
Feb 27, 2024 04:44 AM
paddyx350
Jun 5, 2022 03:23 PM
Riley VanSuetendael
Mar 28, 2022 07:13 PM
Stumpy
Aug 27, 2020 11:14 AM
Walter1982
Jan 13, 2009 10:59 PM
