Crazy Electrics
Old Dec 16, 2013 | 02:18 PM
steveeasy's Avatar
Default Crazy Electrics
Hi All,
Went to use my 97 XK8 the other day after it being not used for several weeks and when it was fired up all the lights inside and out flashed brighter and dimmer continuously and the engine does the same. then the engine and lights settle down, but at the same time the battery volt meter inside on dash goes of the scale. at the same time the gearbox and traction control come up as faulty.
Have put meter on battery, Initially when lights go crazy meter reads everywhere between 12-13. then it goes right up to 17-18 volts.
codes coming up are as follows P1793 and Mode A, Mode 3, and Mode7. Im thinking alternator causing some sort of electrical surge affecting the gearbox but really do not know.
Any help or ideas much appreciated.
Steveeasy
Old Dec 16, 2013 | 02:22 PM
jimbov8's Avatar
Steve, get that alternator off the car before it fries something.
Have it checked then repair or replace. While you are doing that, get the battery fully charged and check the engine bay ground points.
Hope this helps,
WhiteXKR's Avatar
Did you have to jump start it due to a dead battery to get it started?
Old Dec 16, 2013 | 02:35 PM
steveeasy's Avatar
Hi,
Thanks both for such swift responses. Well several weeks ago I did have a flat battery after the car not being used for a while. I did put a booster on it, started fine. battery seams fine now, Could it have been my fast charger that has caused damage to the alternator ?,
steveeasy
Newark Nj Gang
Oct 2, 2015 02:39 PM
Glenn Barickman
Oct 1, 2015 04:09 PM
JagBrian
Oct 1, 2015 12:52 AM
John Fox
Sep 30, 2015 03:17 PM
