Creaking Soft Top
Old Apr 20, 2008 | 01:23 PM
Campeon's Avatar
Default Creaking Soft Top
I had an annoying creaking sound in my XKR convertible that at first I thought was coming from the dash. At low speed and hitting any kind of rise in the road it would happen.
Yesterday I wasdriving with the top down and after the ride I realized I never heard the creak during the drive. Bells went off and this morning I used some white lithium grease on the latch, and two inserts on the top that fit into the top of the windshield and no more noise.
I'm far from being a tech, but it seems I got lucky on this one.
Old Apr 20, 2008 | 01:41 PM
GordoCatCar's Avatar
Default RE: Creaking Soft Top
Good trouble shooting and preventive maintenance of the top squeak.
To further prevent squeak-like noises,vinyl-rubber protectorant [not ArmorAll] is applied and rubbed intothe rubberweatherstripingthat runs alongthe top of the windshield header . Actually this lube/sprayis used throughout the car on all rubber weatherstriping.
And after reading your post, I went out and lubricated the articulating joints of the top's metal frame. I used either machine oil, lithium grease, or WD-40 depending on location, function, or proximity to the headliner or canvas top material. gordo
Old Apr 20, 2008 | 03:47 PM
jag_genius's Avatar
thats a very common noise the latches and locking tabs get dry and noisy.. glad you found it.
Old Apr 20, 2008 | 06:25 PM
Campeon's Avatar
Thanks, Gordo. I'll follow your lead and do the rest.
Old Apr 20, 2008 | 07:50 PM
Just be very careful that oil or grease does not drip onto, or seep through to your headliner. I use machine oil, but just a drop or two, and have a rag at the ready to wipe the joint of excess oil. On sections where thisis too close to the fabric, I use WD40. gordo
Old Apr 15, 2015 | 10:34 PM
howdoyousayjaguar's Avatar
If you're still on this forum, can you specify what and where you inserted in the tip of the windshield?
Mack
May 14, 2020 08:51 AM
CXJ
Nov 28, 2015 11:41 PM
JagBrian
Sep 21, 2015 07:17 PM
picard
Sep 19, 2015 08:13 PM
vicom
Sep 17, 2015 03:32 AM
