cruise control & washer problem
Old May 22, 2014 | 07:29 AM
tony bosco's Avatar
Cool cruise control & washer problem
hello forum, 2001 xk8 no cruise and also washer fluid dosen't squirt onto headlights dosen't pop out either .... vacuum problem ???????? also is there a light to tell you when to change the oil on the 2001 xk8 or just keep track ????? thanks for your help...
Old May 23, 2014 | 09:24 AM
East Haddam's Avatar
When holding the wash function on for what seems like a long time trying to activate the headlamp washers are you seeing washer fluid dripping onto the ground up front? You didn't mention if the windshield washers are working? If you're getting puddles up front it's likely that the lamp washers are 'crudded'/stuck and no amount of vacuum is going to make them work without a little mechanical help getting the nozzles out where they work. I've used a dental pick to help pull washers free from two of my past cars with no damage or marks that corrected the problem.
Cruise control activation is likely electronic more than vacuum related. Someone with a bit more smarts than me about accessories will likely chime in and offer you a possible cure. Curious to see what the problem was as well as what the fix is. You've checked the fuses, right?
RB
Old May 23, 2014 | 10:10 AM
RJ237's Avatar
Your cruise control is electronic, not vacuum like the AJ26. I don't think you have any oil change aids, but not positive.
Old May 23, 2014 | 10:14 AM
Jandreu's Avatar
The headlight washers only work when the lights are on. They are water pressure powered not vacuum. At least that's what my 03 manual says.
Old May 23, 2014 | 11:13 AM
tony bosco's Avatar
windshield washer does work.. washers on headlight does not pop out at all... have tried with the lights on also.. no water up front either.. we'll keep trying thanks guys
Old May 23, 2014 | 11:14 AM
tony bosco's Avatar
fuses see to be all working and in order too.
XJsc-guy
Sep 25, 2015 11:09 AM
Skeeter
Sep 17, 2015 08:15 PM
al_roethlisberger
Sep 11, 2015 10:04 PM
laserguy
Sep 3, 2015 02:02 PM
XFR_Gold
Sep 2, 2015 12:24 PM
