Cylinder head gasket replacement
Old Feb 22, 2021 | 03:45 PM
Ron McGarity's Avatar
Default Cylinder head gasket replacement
Hello - I am looking at a 2013 XK8 to buy and it has had consistent servicing on it since new but it only has 60000 miles on it and it had an A/C compressor replaced and a cylinder head gasket replaced. A/C doesn't bother me (no like new), but the CH gasket seems odd... any ideas or similar experiences from anyone out there? It was replaced by a dealer so maybe all is OK now? Thoights? Thank you!
Old Feb 22, 2021 | 03:58 PM
giandanielxk8's Avatar
  1. You posted this in the wrong section. A 2013 XK is an aluminum-bodied X150, not a steel-bodied X100.
  2. A replaced head gasket probably means that the car overheated. My guess, the 5.0 V8 in the X150s is known for weak water pumps. Is the water pump not in the service history? It's probably OK now, but do look for the telltale signs of a bad head gasket: Oil in coolant, or the coolant in the oil, sweet-smelling exhaust, altered coolant pH, loss of coolant or oil with one or more of the previously mentioned symptoms, to name a few.
Old Feb 22, 2021 | 04:50 PM
NBCat's Avatar
If the vehicle has been overheated sufficiently to ruin the head gasket(s), the block and or cylinder heads may have also warped meaning the head gasket(s) may fail again shortly.
Old Feb 23, 2021 | 09:49 AM
Thank you for the good information - I think I will look for a different XK! RM
Old Feb 23, 2021 | 09:50 AM
Thank you for the information - I think I will look for a different XK to purchase! RM
Roberto Caria
Dec 4, 2023 01:01 AM
BadDog
Dec 3, 2021 06:47 PM
Chris Hebb
Dec 26, 2017 09:36 PM
Gander
Sep 17, 2015 12:51 PM
pschuit
May 13, 2011 11:13 AM
