Daily Use Of The Convertible Top Is It Safe To Do This ?
Old Nov 18, 2009 | 02:47 PM
jagxkrtoofast's Avatar
Banned
Arrow Daily Use Of The Convertible Top Is It Safe To Do This ?
I just aquired an XKR last week and I love it. I love dropping the top. With that being said I like doing everytime I get into the car. But I understand some members have problems with the hydraulics that opens and closes the top. Would daily use cause a problem ? Has anyone not had a problem ? Please advise. Thanks
Old Nov 18, 2009 | 03:29 PM
test point's Avatar
Daily use is not so much an issue as the design weaknesses of the system. Many have had leaks but they appear to be based more heat deterioration and pressure spikes than number of cycles.
Check the FAQ above for complete discussions on the issues and what appears to be the current solution.
Old Nov 18, 2009 | 03:42 PM
SeismicGuy's Avatar
You have a 2006 which, presumably, should still be under some warranty--either the balance of the original 48 month one of an extended Select Edition (if the previous owner had that). So you might be better off by using the top as much as possible to see if any problems develop.
Better yet, Gus and Walt (who regularly post here) came up with a gizmo that addresses what appears to be the primary cause of the hydraulic problems. Namely, excessive pressure above and beyond what is really needed to activate the opening/closing operation. It would be a good idea to install one of these to greatly reduce the potential for problems.
Doug
Old Nov 18, 2009 | 07:11 PM
Gus's Avatar
Gus
Unable to say your roof is just fine, chances are it is. We have several posts on the subject and one that addresses the pressure relief valve that Walt designed. You could if you wish to go to my page and read my posts on the roof failures and suggestions to make repairs and modifications. If you wish you can ask questions after you review the past posts and we will do all we can to help.
FrickenJag
Jun 16, 2025 02:15 PM
99xk8guy
May 28, 2024 09:36 PM
Rivguy
Dec 4, 2020 07:55 AM
Daim
Nov 28, 2016 09:28 AM
Rlover
Mar 30, 2016 10:04 PM
