Dash lights go out when I turn on headlights
Old Apr 11, 2014 | 01:58 PM
convgto69's Avatar
Originally Posted by jimbov8
Sounds as you have found the problem. You could open up and see if it is repairable, though a new one maybe your best bet.
At least now you are one step closer to a result.
Originally Posted by convgto69
Thanks. I am checking around to see if I can find one locally. I will let you know when I replace it and am sure that solved the problem.
thx.
Jim
Ok guys, I replaced the dimmer module and the fuse still is blowing. I am going to replace the signal stalk next. I have one so I think that makes sense. Please let me know if you can think of anything else.
thx.
Jim
Old May 17, 2014 | 06:39 PM
convgto69's Avatar
Ok guys. HELP please. I finally had the time to digdeeper into my problem. I changed the dimmer control module and still blew the 10 amp fuse in the #18 slot in the fuse box on passenger side. So I pulled the steering column and signal stalk to see if a wire was broken. Nope no good. All wires were intact. So I changed the stalk with a used one. Fingers crossed it would work. Nope , still blows use and dash lights go off when I turn on headlights. So what's next. I appreciate any feedback. I live out on Eastern Long Island NY and would consider a mechanic if I can't get it solved. Thx Guys.
Old May 18, 2014 | 10:24 AM
DpezXK8's Avatar
Sorry to hear,
Do your dash lights come on in any circumstance? I know when I start mine when it's dark out they do come on without the headlights. It definately a short somewhere in the system.
Wasn't sure if a blown bulb could be shorting or a damaged bulb socket. Are all the dash lights on?
If you can't find it I would think an electrician or electrical engineer would be a better choice for troubleshooting if you know any. You have the schematics and I think they could troubleshoot better. I expect a mechanic would replace a harness.
I'll look at the schematics again and see if I could come up with some kind of troubleshooting list that I would follow.
If you could please post a list of what exactly you've done to this point. It may help others that see the thread instead of reading thriough the whole post.
Old May 18, 2014 | 11:46 AM
aode06's Avatar
Check your installation of your LCD screen that you installed a few days ago?. That was you right?
Old May 18, 2014 | 12:33 PM
BurgXK8's Avatar
Any possibility there is a steering column shim that slipped down and contacted a wire somewhere? I had that part fall out when I adjusted the steering column level right after I bought the car. It's a little piece of metal and everybody says you don't even need it, but I can imagine it chafing a wire insulation somewhere if it got dislodged and is still floating around unsupervised. My two cents.
Old May 19, 2014 | 05:54 PM
convgto69's Avatar
The dash lights come on when I start the car. They go out and the fuse blows when I turn the lights on. The fuse is on the passenger side #18 , 10 amps. I replaced the dimmer control module and the signal stalk. Thats what I have done so far. I will check the wiring around the steering column as suggested. If all else fails I will bring her to Jagpro in Bellmore Long Island and have Martin fix it.
Old May 20, 2014 | 07:35 AM
aode06's Avatar
Broken wire in turn signal switch and a resulting blown fuse is the cause to this problem. Replace turn signal switch and fuse should cure the problem.
and also make sure the fuse in the drivers side rear seat fuse box get's replaced if this is applicable to your situation
Old May 23, 2014 | 05:56 PM
  #28
convgto69's Avatar
Guys,
Thank you for all the responses. I will advise after I do some more searching for a chafed wire. I replaced the stalk and still had the issue. I will figure it out. I just need some time.
Old May 23, 2014 | 10:22 PM
aode06's Avatar
check the solid green wire soldered to the stalk, and the others, they may need re soldered as well.
JarodL
Mar 7, 2024 01:39 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
afterburner1
Dec 16, 2015 12:12 AM
laserguy
Sep 3, 2015 02:02 PM
King Charles
Sep 3, 2015 12:40 AM
