Dashboard trim cleaner
Old Dec 27, 2015 | 10:05 PM
dogsoup's Avatar
Default Dashboard trim cleaner
Was wondering how you guys clean the dash trim which I believe is some kind of compressed leather. For the wooden part I've been using a very mild soap solution. Is there a better method for the wood part?
Old Dec 28, 2015 | 01:30 AM
StuG's Avatar
This question was asked on another car forum that I frequent and the overwhelming response was "Magic Eraser".
I went out and purchased it and couldn't be happier with the results. It also works well on the veneer followed by a quick wipe with a microfibre cloth. I use it on the dash, door panels and steering wheel. Does a great job on the leather seats just before applying leather conditioner.
Cheers,
Stu
Old Dec 28, 2015 | 03:57 AM
jamdmyers's Avatar
One thing I've learned about detailing is you never use anything 'dry' either on the interior or exterior. Even wiping dust off the paint dry will leave microscopic scratches. There is a detailing forum on this site you might want to check out.
As far as Magic Erasure Read this link, you're basically sanding the dirt away, which regardless of the materiel will leave some form of scratches.
If you use one you should use some form of lubricant with it ie your fav interior polish or what not.
Old Dec 28, 2015 | 06:54 AM
dogsoup's Avatar
Thanks for the feedback. Will check it out in more detail
Old Dec 28, 2015 | 07:13 AM
ccfulton's Avatar
The dash top is plastic molded to look like leather. Same with the door tops.
I use a damp microfiber cloth on the "fluffy" side for the interior. Gets dust out of switches and gauges pretty well.
If something is really dirty, simple green and a toothbrush is a great degreaser for small spaces.
Old Dec 28, 2015 | 04:45 PM
Jag#4's Avatar
Heat and sun are an issue here for me, so I follow-up with a coating of 303 aerospace protectant. It seals the vinyl/plastic and blocks the damaging UV rays. It is available in most marine or boat stores.
01Silverstone
Jan 29, 2016 02:54 PM
01Silverstone
Jan 29, 2016 02:51 PM
Lemons Racer
Jan 25, 2016 04:33 PM
Vtjaguarlover
Jan 4, 2016 08:51 PM
Revere
Jan 1, 2016 10:50 AM
