Daytime Running lights again.
Old Nov 17, 2025 | 07:56 AM
motorcarman's Avatar
My 1998 INSTPK gets 'SLIGHTLY' dimmer with the headlamps in the OFF position and reacts to the dimmer with switch in any other position.
Old Nov 17, 2025 | 12:09 PM
Brian G's Avatar
Originally Posted by dibbit
Check your dashlights dimmer knob - this controls the dash lights with the headlights on. When the headlights are off, the dashlights are on full brightness.
The dimmer knob has no effect on the dash lights when ign sw is on and headlight sw is off.... the dash lighting is not illuminated. The dimmer works normally with headlight switch in any "on" position.
The Canadian DRL setting has the low beam headlight running at 100% regarless of headlight switch setting. Low beam remains on even when high beam is selected.
Old Nov 17, 2025 | 12:14 PM
Brian G's Avatar
This is interesting. One might expect full brightness during daylight (headlights off) operation.
I checked this in my darkened garage and found no lighting of the dash lights with ign sw on and headlight switched off.
I'm beginning to wonder whether a wire has broken off at the headlight switch stock module in the steering column. Forum posts elsewhere seem to identify this as a source of a number of issues. I'm just waiting to see if someone with 4.2 car that has Canadian DRL enabled chimes in with their experience of dash lights in the ign on/headlight off situation.
Old Jan 15, 2026 | 05:46 AM
cdma's Avatar
From what I have read the 1997 XK8 BCM is not the same as later models and it cannot be adjusted with the IDS? I also have found that you cannot even change out the BCM for a later model due to a number of sensors that are needed that are not available for the 1997.
Old Jan 16, 2026 | 01:02 PM
jhuertas's Avatar
I've fitted Hella LED daytime running lights to my XK8. They come with the relay and are easy to connect. I got the idea from another forum member's thread. They're really useful these days with all the bike lanes. I've already registered them on my vehicle registration document.
Todd Wiens
Oct 6, 2021 04:49 PM
gmakel
General Tech Help
Mar 12, 2018 11:13 AM
Dela Quao
Oct 30, 2016 05:29 AM
simplesimon
XJ40 ( XJ81 )
Apr 30, 2013 09:36 PM
TonyB
Mar 27, 2010 06:15 PM
