De-pin a Delphi Connector, ABS/Wheel Speed Sensor
Old Jun 25, 2021 | 08:15 AM
kstevusa's Avatar
Default De-pin a Delphi Connector, ABS/Wheel Speed Sensor
Have the Dreaded ABS Speed Sensor wire harness problem. (current best price $155 + S&H) The R.F.is intermittent and triggered the DSC Fault occasionally. Finally got assistance and used the connector at the shock tower to test by Wiggle Method. The wire at the strain relief and plug (Delphi) was defective. I have several dedicated tools for disassembly but unable to de-pin. Would someone share a link to a applicable video or provide details for removing the pins so wire and new terminals can be replaced. I have searched this forum and Google but found no applicable info on this connector.
Old Jun 25, 2021 | 09:41 AM
TropicCat's Avatar
Try the chatbot @ FindPigTails.com. If they source that connector they can tell you how to remove/replace the pins. They may even have a video.
Old Jun 26, 2021 | 10:14 PM
crbass's Avatar
Unfortunately, many of the connectors, at this point, are friable and fragile. If you're fixing them yourself all the time, something like this terminal tool set pays for itself (down to about 2$ a serving on my jags alone, expect the cost to be negligible across all time used). There are others that are cheaper too.
Amazon Amazon
I believe your connector (through 03) should be a "2-WAY REINSHAGEN METRI 630". A picture is on this web site which should give you an idea of where to push to release the pin.
https://www.waytekwire.com/item/4601...ay-630-Series/
These are also widely available from Aptiv (ex Delphi) on Mouser and other sites, so you can replace pins and connector body if you wish.
Old Jun 28, 2021 | 03:32 AM
kansanbrit's Avatar
Get one from a junker and spice the wires.
Old Jun 28, 2021 | 06:15 AM
kstevusa's Avatar
Thank for suggestions, since we know cause (damaged wire) of DSC and ABS warnings, LKQ are all old. Subject to same problem. I purchased a new one and may attempt to fab a replacement just to say I did it. Some will understand. :-)
scottatl
Apr 30, 2019 10:20 PM
jagnut
XJ40 ( XJ81 )
Oct 2, 2018 07:21 PM
vkng7
Dec 2, 2015 09:21 PM
scardini1
Aug 25, 2015 10:09 AM
marcgr
May 24, 2014 01:48 PM
