Dead Battery - Auxiliary Fuse Box
Old Dec 26, 2010 | 07:11 AM
JagYour's Avatar
Default Dead Battery - Auxiliary Fuse Box
My battery is dead and I need to re charge it. Can't open the trunk. My key does not work when I insert it into the "XK8" emblem. I knew this prior but never had a chance to fix it or free it up. Can I jump the car from the terminals on the fuse box in the engine bay? Or, should I only use a trickle charge on that terminal?
Old Dec 26, 2010 | 07:37 AM
test point's Avatar
You can jump it but I always leave the batteries connected for a minute or two before trying the starter. Think someone told me that when I was 16 and I never bothered to change.
Old Dec 26, 2010 | 09:02 AM
Reverend Sam's Avatar
What test point said. Although, as soon as you put power on those terminals you should be able to open the trunk electrically.
Old Dec 26, 2010 | 09:39 AM
Dennis07's Avatar
Best practice would be to get the trunk open and then move the jumpers to the battery before engaging the starter.
There is a 250 amp fuse in the circuit leading to these terminals. That's probably enough with all but the deadest of batteries, all but the coldest of conditions. The car *can* be jump started from these terminals, but this should be a last resort; only if there's no way to get into the trunk.
If forced to go this way, as test_point said, best to leave the jumpers connected for a few minutes before engaging the starter.
Last edited by Dennis07; Dec 26, 2010 at 04:08 PM. Reason: Initial post had an error; I read the schematic wrong
Old Dec 26, 2010 | 10:43 AM
Paul Pavlik's Avatar
You can Charge the Battery using the Terminals in the Engine Bay. Then you can open the Trunk Electrically. Do not attempt to Start the car from the Engine Bay Terminals:
Dagny
Jun 11, 2024 01:06 PM
99xk8guy
May 28, 2024 09:36 PM
BadKat174
May 26, 2023 12:29 AM
abonano
25
Sep 25, 2015 10:43 AM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
