Dead battery trunk opening tip
Old Aug 14, 2015 | 03:47 PM
Ophitoxaemia's Avatar
Default Dead battery trunk opening tip
Try every key.
Trying to get into the trunk using the mechanical key release in the "XK8" never worked for me. I figured the mechanism was stuck. But I just tried my second black key and it opened right up. Perhaps the wear of the key used in the ignition affects the fit?
Hoping this helps someone else save some effort.
Old Aug 14, 2015 | 04:16 PM
waterloo's Avatar
I believe it may be because one is a valet key that is unable to open the trunk
Old Aug 14, 2015 | 04:36 PM
test point's Avatar
You can always hook up a battery/charger to the under hood connections and open it as usual.
Old Aug 14, 2015 | 09:58 PM
Gus's Avatar
Gus
Green key is the Valet keys.
Old Aug 22, 2015 | 10:31 PM
If the battery is dead, the doors won't open with the key, so it's hard to open the hood. If you can get into the trunk, you can power the system that will open the doors through the battery connections.
Yes, the green is the valet, which is why I mentioned it was my second black key that worked.
dsnyder586
Dec 29, 2024 07:39 PM
99xk8guy
May 28, 2024 09:36 PM
mbergen
Oct 23, 2019 10:26 PM
martybmw
Apr 2, 2016 04:55 AM
prettydaim
Sep 7, 2015 05:16 PM
