Defroster problem
Old Jul 6, 2014 | 07:50 AM
Loxmth's Avatar
Default Defroster problem
Good morning,
I'm new to this forum and have a problem with the defrosted on my 2003 XK8 convertible. The other day with the top up and nothing on my windshield started to fog up. Opened both windows a bit and it cleared up. Closed the windows and it fog again. Turned the defroster on and it iced a little. Turn the temperature up to no avail. Temperature outside was about 60 degrees F. Yesterday with the top down I started it up and it fogged a bit then cleared up in a few seconds. I was thinking heater core but no smell or loss of antifreeze. Any ideas?
Old Jul 6, 2014 | 08:08 AM
Jag#4's Avatar
Plenty of threads on the forum about the HVAC system. Usually it's the lack of heat due to failing pump or valve.
(here's one: https://www.jaguarforums.com/forum/x...ng-well-66815/)
What I don't get is how you iced the windshield with it being 60 degrees outside. Ignoring the fact that at 60* I'd have the top down, how did you produce ice?
The cabins in the 'verts are pretty snug, so the combination of hot air (breath) against cool outside air will fog them pretty fast. The A/C does most of the work by taking out the humidity. Is your A/C getting cold?
Old Jul 6, 2014 | 08:29 AM
Loxmth's Avatar
Default Defroster
It iced a bit when I turned on the defroster which in turn turns on the AC. The top was up because when I left for a 1 hr trip on the highway it was 50.
Old Jul 6, 2014 | 09:48 AM
Loxmth's Avatar
Did a quick search and found its a common problem. Cabin filter and/or recirculate air door. Going to check both tomorrow.
Should have done the search first,duh
Clamdigger
Sep 12, 2015 03:43 PM
dragonfly777
Regional
Sep 8, 2015 01:39 PM
mcdutch
Sep 4, 2015 03:38 AM
obwoodie
Sep 3, 2015 07:45 PM
laserguy
Sep 3, 2015 02:02 PM
