Did my ECM really reset?
Old Aug 23, 2018 | 09:42 AM
alanroberts50's Avatar
Default Did my ECM really reset?
So I held the neg cable onto the pos post with the pos cable still connected for about 5-6 seconds with the ign on as suggested.
After reconnecting, the idle was high but came back to normal pretty quickly.
windows needed a reset
I then let it idle for 2-3 mins with the air and rear defrost on
A further 2min idle in Drive position (footbrake on!)
After connecting the code reader to check the monitors they were exactly the same as before, everything was ready except the "cat not ready" monitor.
I guess my question is that will all the monitors reset (except the cat) just from idling a total of about 5 mins or am I still just seeing the old readings?
Old Aug 23, 2018 | 10:00 AM
RJ237's Avatar
Yes, it did reset. Did you get a P1000 indicating internal testing not complete? You will need to go through several drive cycles before it will display P1111 indicating self test complete. Sometimes it's necessary to go through a complicated drive cycle :Drive Cycle.pdf
Old Aug 23, 2018 | 10:12 AM
Thanks, yes but the P1000 was there before, due to a battery swap. Been trying for months and a thousand miles to get rid of the cat not ready which wasn't there before the battery swap.
I love it when people say "just drive for 5 mins at between 1700-2500 rpm. Drive cycles up the wazoo. Nothing works!
Old Aug 23, 2018 | 10:59 AM
avern1's Avatar
Drive cycles repeated is unfortunately the only real way to set all monitors. If you have done the drive cycles and still can't get the monitor for the cats to set you are going to have to look for codes pending. If your reader can't give codes pending them try to find a source for one that can. You may have a minor problem that won't set a code based on repeating the condition but still won't clear the code.
Since you know it is the cat monitor I would recommend disconnecting the sensors one at a time and cleaning the contacts and reconnecting. Also visually inspect each of the sensor cables for any insulation damage. Damaged insulation on the connector cable will give an occasional fault but not a repeatable fault. Offhand I don't remember for sure but I think the fault has to repeat 4 or 5 times to throw a code and illuminate the check engine light.
Old Aug 23, 2018 | 04:32 PM
Thank you! Do you know which sensors? How many and their locations?
Alan
mello12u
Mar 29, 2015 06:01 PM
jazzwineman
Jun 29, 2014 07:58 AM
McJaguar
Oct 18, 2012 03:03 AM
chazaroo
Dec 30, 2009 07:39 PM
badmojo
May 4, 2007 05:51 PM
