Differences between Aj27 and Aj28
Old Sep 5, 2016 | 01:03 PM
NIgor's Avatar
Default Differences between Aj27 and Aj28
Hello
There is Jag Xk8 -01 for sale and seller says there is 1st cylinder valve is stucked. I'm afraid that is nikasil problem.
There is also one S-Type -00 with 4.0 v8 for sale which is badly crashed but has good engine.
So I think what differences there is between Xk8 Aj27 and S-type Aj28?
Old Sep 5, 2016 | 07:24 PM
RJ237's Avatar
A stuck valve is not an indication of a nikasil problem, but might be a failed chain tensioner causing a bent valve, or overheating causing a dropped valve seat. It might be repairable.
I'm not certain about the S type engine so I'll not comment.
Old Sep 5, 2016 | 07:33 PM
motorcarman's Avatar
ALL 4.0 Jaguar blocks will fit any AJ26, AJ27 or AJ28 application. The oil sump and heads are different as well as the front timing covers. The sensors, brackets, accessories etc. are all different but the mount holes are all there.
Any 4.0 can be made to work if you have BOTH the original and the replacement side-by-side and create the one you need.
bob
Old Sep 6, 2016 | 02:29 AM
NIgor's Avatar
But i think seller may try to cheat.
But it is great if block is same
I will call and go see that xk8
Thank you for help!
Old Sep 6, 2016 | 02:39 AM
NIgor's Avatar
Car is running but with 7 cylinder. I dont know how seller knows it is valve problem but if he tested 1st cyl pressure and there wasnt or it is low it can also be nikasil, right?
Old Sep 6, 2016 | 02:45 AM
bladerunner919's Avatar
Could be many things, but nikasil is the least likely as it's only one piston. Nikasil was damaged by high-sulfur fuel that hasn't be around for years and years.
It could be anything from a head gasket leak to a hole in a piston. Unless you have a very good reason to buy this one, I'd steer clear.
RAT572762
General Tech Help
May 24, 2016 06:30 PM
StuG
Australia - Queensland
Apr 26, 2016 08:49 PM
sickboy
Jun 2, 2007 10:20 PM
Exterior
Mar 30, 2006 03:41 PM
