Different bolt for cam cover fixing near sensor?
Old Jun 13, 2020 | 01:03 PM
O&DR's Avatar
Default Different bolt for cam cover fixing near sensor?
Just finished my cam chains, tensioners and guides.
Someone has suggested there is a different bolt to use for the LHS cam cover fixing nearest the cam position sensor.
Something to do with the steel effecting and magnetic action ‘Hall effect’ of the sensor.
Could not find a different bolt visually.
All looked the same from the top (8.8 stamped).
So as a precaution, changed that bolt and a slightly shorter stainless one.
Have a radio interference issue thought things might help but didn’t.
Anyone heard of this issue with the cam cover bolt nearest the cam sensor?
Old Jun 13, 2020 | 01:59 PM
motorcarman's Avatar
The bolt IS different on both covers in that location.
Someone has been there before you if it is the same as all the others.
Old Jun 13, 2020 | 03:36 PM
O&DR's Avatar
Thank you for your reply.
Mixed them all up when removing.
Didn’t known there was a difference.
Do you know how it is different ?
shorter or different material?
PS - I don’t had a cam sensor on the RHS bank from what I can see.
Old Jun 13, 2020 | 04:16 PM
The bolt in question is not CAPTIVE and the mount/spacer with the isolators is free to accept the bolt. (it is the one that the bolt fell out of)
It is also CADMIUM plated and a slightly different color.
Old Jun 13, 2020 | 06:27 PM
michaelh's Avatar
Member BobRoy kindly posted a picture showing the difference:
https://www.jaguarforums.com/forum/x...3/#post1658791
Old Aug 1, 2020 | 02:36 AM
O&DR's Avatar
Cam cover bolt different V46 Jaguar XK8 / XKR (X100)
xjr2014_de
May 16, 2021 04:03 AM
Jacob Collins
Jan 10, 2017 02:08 AM
Alan Stoldt
Apr 10, 2016 07:37 AM
JonLee
Feb 23, 2014 11:18 AM
JagYour
May 17, 2012 06:45 AM
