differential
Old Aug 23, 2009 | 07:29 PM
2000blackxkr's Avatar
Question differential
I am trying to understand what differential is used in my 2000 xkr.
i have found that jag used dana 44's a long time ago and there is also a off shoot known as a "Salsbury". Does this apply to my 00? or is there some other unit used on my generation of xk8/r??
Old Aug 24, 2009 | 01:18 AM
whiteSTR's Avatar
I'm almost certain that it's a variation of the ford 8.8 rear. The same one used in mustangs and lincoln ls's. It uses a different carrier than mustangs, so if your planning on installing a cobra lsd or something similar, some modifications are necessary.
Old Aug 24, 2009 | 03:27 PM
Default dif
i was thinking about it as i am starting to get some noise from my rear end after a good long drive, i need to get the fluid changed.
if i have to rebuild it, i want to put lsd in there. But there has got to be a way to do the rebuild/mod without having to order jag parts.
they want WAY WAY to much money for dif parts.
Old Aug 24, 2009 | 06:35 PM
JagtechOhio's Avatar
Jag didn't do a limited slip for your car. This discussion resurfaces from time to time, here is a recent thread from people in the know:
https://www.jaguarforums.com/forum/s...p+differential
Dana was XJS, the one used in your car may in fact be referred to as a Salisbury but I don't know. I can check to verify fitment for your car, but I believe the XJ8 uses the identical diff. PM me if you need more info, good used ones are relatively cheap.
Old Aug 24, 2009 | 09:51 PM
Red face diff
Thank you jag tech.
I am interested in figment for this car as i have been unable to find any info concerning the xk series at all on the net. I have searched several jag forums. It would be nice to know which rear end is under my car.
Old Aug 25, 2009 | 12:23 AM
avos's Avatar
Chances are the unit itself is from DANA in the UK, at least that is someone saying at pistonheads.com, and I have seen the wording DANA on the gearing , not sure if that will help you. Gearing is the most expensive, if that is the case better to look for a low mileage 2nd hand one.
I think the units are the same X308 cars with 3.06 gear ratio, but the 2003-2006 XKRs have a 2.87 gear ratio.
Andre.
Old Aug 27, 2009 | 01:45 PM
Cool dif
if you look at this pic, it leads me to believe that this is NOT a dana. if it is its the strangest design i have ever seen.
https://www.trademotion.com/schemati...al/F300121.gif
Old Aug 28, 2009 | 01:43 AM
avos's Avatar
This is not a Diff from a XK8/R, as you can see it shows the plates for a limmited slip. This is for the early cars ie older XJ, XJS, XJ40 etc, not sure which.
Old Aug 28, 2009 | 02:19 AM
We'll see if this link works, this is from 1995-1997 XJ6 and shows "Powr-lok", which is what Jaguar calls there limited slip differentials:
http://www.captainjaguarscathouse.co...f_4/2_E_16.tif
That lists 3.27 as the supercharged unit, and also shows 3.58, 3.77, and 4.09 gears.
Here's the exploded view and parts list:
http://www.captainjaguarscathouse.co...f_4/2_F_02.tif
I'll see what else I can find out...
Old Aug 28, 2009 | 11:30 AM
Default ok
The pic i posted was from jaguarparts.com
looks like there diagrams are wrong.
Old Dec 18, 2012 | 10:23 PM
stephenecoe's Avatar
I have a 2000 xk8 w 78k just started a very loud noise,1 shop says the dif is bad needs a$2000 replacement.the local jag dealer says there is no repare for this,just replace the whole dif unit.Any ideas would be great. has anyone replaced the pinion bearings.TKS steve coe
Old Dec 19, 2012 | 03:48 AM
mjlaris's Avatar
I cannot speak to replacing the pinion bearings but I did replace my differential with one I bought from another forum member that had a 3.27 rear axle ratio and came with a new (reprogrammed) TCM (needed to change the axle ratio in XKRs with Mercedes transmissions). I paid $2k for the differential and the new TCM (a good deal as the reprogramming on the TCM costs $2k by itself). I upgraded to a Quaife LSD at the same time, which cost $1.5k. The labor at my local independent Jag shop was just under $1k. Not a cheep mod!
Mark
hoodun
May 15, 2019 09:31 PM
Dave1109971
Dec 15, 2015 06:16 PM
Woznaldo
Sep 26, 2015 11:02 AM
AtholC
Sep 9, 2015 09:07 PM
