Differential fluid change
Old May 1, 2012 | 04:24 PM
Max's Avatar
Max
Default Differential fluid change
Has anyone changed the differential fluid without having to drop the rear end of an XK8 or know of listed procedures to do so?
Thanks.
Old May 1, 2012 | 05:29 PM
RCSign's Avatar
Max
The JTIS says it's sealed for life but we all know how well that worked out with the transmissions. I too would be interested in the procedure for changing it.
Old May 1, 2012 | 06:17 PM
deadboy1977's Avatar
dealer near me has a special for fluid change like 165$ so i guess its doable! i'd also like to know HOW to do it...one of the techs on here must know!
Old May 2, 2012 | 12:55 AM
avos's Avatar
Here is a way:
https://www.jaguarforums.com/forum/x...iff-oil-71492/
You could also take of the rear strut brace (not sure the naming, so attached the picture), that way you have easier access to take out the filling plug, and syphon out/refill the oil.
You can use Castrol Syntrax Longlife for instance.
aholbro1
Dec 29, 2024 06:46 PM
Jandreu
Jun 30, 2022 03:10 PM
kstevusa
Sep 7, 2015 01:12 PM
Wes Steenrod
Sep 6, 2015 06:52 PM
pnwrs2000
Sep 3, 2015 11:55 AM
