Differential service , advice
Old Jun 25, 2018 | 01:01 PM
David F.'s Avatar
Default Differential service , advice
Its time for a service on my diff and according to my research I have two options.
My car is a 2000 XK8 convertible.
Option one, is getting a 1 inch by 1/2 inch piece of bar stock and using it to remove the fill plug. I assume you use a ratchet wrench to remove the plug, remove the old fluid with a pump and refill.
Option two is cutting a two inch hole in the trunk / boot sheet metal opposite the fill plug for easier access. Again using a pump to drain and fill the diff.
I would sure appreciate anyone who has experience with either method sharing their experience.
Old Jun 25, 2018 | 01:32 PM
RJ237's Avatar
I have done both. For the 4.2L the bar stock is the only option, but it can be almost impossible to break the plug loose. Before you cut check the link below:
Differential Fill Plug Removal - Jaguar Forums - Jaguar Enthusiasts Forum
Old Jun 25, 2018 | 08:09 PM
Gus's Avatar
Gus
This is how i did my 99.
SLazz
Mar 27, 2018 04:45 PM
swingwing
Apr 2, 2017 04:18 PM
pab
Dec 28, 2015 07:58 AM
Mendo XK
May 22, 2013 12:46 PM
daboss085
Mar 19, 2013 12:15 PM
